LB7 LML Allison 1000 conversion & swap
Lennart
Not from here !
Aug 10, 2006
314
Detmold, Germany
Got a 6th gear file, modified it as needed and loaded into TCM. To be safe I did the first trial on a hoist without wheels mounted.
Logged the data with HPTuners, TCM is commanding 6th but it does not shift into 6th. Only for a split second I saw 6th applied.
It then gets stuck in 5th gear with DTC P0747 Pressure control solenoid "A" stuck on
Then programmed back to 5-gear tune, all working fine. Looks like there is a little more needed in the VB to get it to work.....I wish I could get an inside view of what Suncoast did :)
3,781
355
I recall my transmission guy saying there's one additional hole drilled in the separator plate vs. a 5 speed.
If you have access to a Suncoast conversion you could pull it apart and see where and how big that hole is.
Sent from my CPH2655 using Tapatalk
Deezul23
Feb 2, 2026
Hesperia, CA
Curious where does one get a 6th gear file as I can't seem to find any online? Thanks in advance!
sbornoe
Jan 13, 2019
3
Option 3 the hard way get a LML set up and try to get your new 4x4 system to function. If you are 2x4 it’s even easier. You will need to do some home work I’m working on it now with the 4x4 system as my little brother has time. Using a 2008-2013 can based TCCM I have communication with the scan tool but I only had a 5 position unit on hand and the Duramax uses a 3 position TCCM so until I have time to program it I have a code for the actuator that isn’t present.
How did it go with the tccm? I am trying to bench test my MP1626xhd from same year, 2011 LML NQF transfer case. Using a canbed for communicating with tccm, have connection but cant get it to wake up. Do you have any ideas? There is light in the 3 way switch, can is cooperating but no wakey wakey..
Bdsankey
4,817
1,862
Larsen, Wisconsin
Unfortunately the OP will never be able to respond to you.
He repeatedly broke the rules and was banned from the forum.
upstate29353
Mar 14, 2023
3
29316
I have a LB7 i have access to a complete 2015 to get all I need to do the complete swap
My question is what will I have to do to complete the swap at little cost thx.
