Anyone help with trouble shooting 6.6L gasser hard start?
5,101
703
2022 chevy 2500 and I have an intermediate hard start. The engine turns over fine it just takes longer than it should to fire. First thing in the morning and if I shut it off and restart it shortly it seems to fire fine. It's after it's been parked for an hour or 2 that it seems to give me issues. I bought the truck probably about 2 months ago. I noticed it a little bit in the beginning but it's gotten significantly worse. I'm assuming a fuel pump but I've read that this code is pretty common and can be a lot of things. Truck has 63k and 2700hrs. I idle a lot, but I don't think the previous owner did. I just go me a Autel 808 scanner, but I'm not sure what I should be looking for especially since it's got 2 pumps.
Code is a 2635 fuel pump A low flow.
These are all from the fuel system data while idling.
Fuel trims look OK I guess
Fuel trim balance test failed?
MAP performance test 1 would go back and forth between Malfunction and ok: no picture
A few Ignition on Malfunctions
2 voltage References were high.
Last is a graph of fuel pressure while staying the throttle. I don't understand why desire didn't go up but I do see a dip at the beginning of actual.
If anyone can point me in the right direction of where to start looking I'd appreciate it or what websites would be good to help me flow chart how to troubleshoot this. I know there's some out there. I just don't remember what they are anymore.
Not sure about the newer trucks. But on some of the older ones, I believe the fuel return pressure regulator was a culprit for long starts when the vehicle sat for long enough. Pressure bled down and it took a while for the pump to refill the lines and build pressure
If you cycle the kay a few times to run the fuel pump, will it start easier?
5,101
703
Ya GM thought this is a Race Truck and has push button start. I'm not sure if putting in in Accessory mode actually turns on the fuel pump or not you can't hear It that's for sure.
I'm not sure if that's the case though anyways because usually it starts fine in the morning. These are like diesels lift pump in the tank and high pressure cam driven pump in the valley.
So, it it having trouble once the engine is warm and it sits for a bit, then it has trouble?
Lennydmaxguy
Just another diesel tech
Nov 8, 2023
131
74
Somewhere, USA :)
Can't remember off the top of my head, does your truck have scan tool PIDs for both supply and rail pressure? If so, I'd monitor both and try to duplicate the long crank. My guess is going to be the high pressure fuel pump is leaking, although I could be wrong. We did have one in our shop with a leaking high pressure pump, and the replacement GM pump looked completely different from the old one. Apparently they had issues with some of them and switched suppliers.
5,101
703
Yes. Seems to start fine in the mornings and if I just shut it down and restart. Like if I go into a store. If it sits for an hour or more is when it has more issues. Anything from just a little delay to 2 Mississippi’s. It was random, but the frequency has definitely increased. Almost to the point it consistently not gonna start right if I park my truck for an hour or 2.
5,101
703
Let me look. That’s what I was thinking as well.
There’s a guy that’s trying to help me out a little bit and he had me do a balance power test and one of my bank of injectors is running lean. I’m trying some fuel injector cleaner and an upper intake clean now. At least if it’s injectors, they’re not as expensive as Duramax injectors. Not sure if I can do them myself though. He said something about needing some special tools and you had to size the O-rings.
Lennydmaxguy
Nov 8, 2023
131
74
Somewhere, USA :)
The seals are flat and wide, and seem to be made of an almost plastic-like material. They need to be stretched over the injector, then compressed in place. You just need 2 tools, a cone to slide the seal over, and a sleeve to slide over the injector. This kit looks like it would work.
1,676
I looked up P2635 under a 2022 - 2500 and this is all that shows up under similar vehicles.
If it has a P018b present as well there are 7 more that show up with the same testing listed below and confirmed 7 people put pumps in them and 1 had to repair the Wiring to the Fuel Pressure Sensor. Most of those were in the 130K mile range though.
5,101
703
Looking more like the fuel pump, but my damn scanner won’t depressurized the fuel system like it should. Duty cycle is 90% at idle. Almost 11amps and 7000rpms. Can’t find a fuse/relay labeled for the fuel pump to try that method. Can someone point me in the right direction?
1,676
Unfortunately you would have to un-plug the pump module itself. The main power also powers other things like the ECU so you cant just pull the fuse.
5,101
703
Well I guess the engine being cold is very specific. After trying it after the truck sat over night it worked fine.
After the truck died it was still reading 30psi. I can't afind anything about a low pressure fuel sensor. There is a high pressure in the rail and a tank pressure(emissions maybe). I'm not sure if this is a calculated value or is the sensor incorporated and the pump assembly?
1,676
There is an additional fuel pressure sensor under the truck connected to the fuel line.
1,676
Do you know what Version of GM Software is on that Autel 808?
According to Autel for the MX808 GM_V18.00 should control what ever fuel options it has.
5,101
703
That fuel pressure sensor location is bad. Look like it is right on top the fuel tank.
It let me once I let the truck sit over night. My truck runs most of the day so it’s hard for me to get a true “cold idle” I guess.
5,101
703
I went ahead just did the fuel pump since it obviously wasn't happy. I'm not sure that the hard star issue is resolved. It only really showed its head when I shut the vehicle off for certain amount of time. Start and stop it just fine but something about getting around that 2 hour mark we're cranking get excessive. But yet overnight in the morning it starts great and always has.
I kind of expected the tank to be a little worse on a truck with no fuel cap. The pump was obviously replaced in the past looks like the tech left me some tape in there. Looks like most of the debris is grass or something. Thats one sorry excuse for a fuel filter too.
