Engine swap holy moly , 06 LBZ into 05 LLY, no start
HDduramax
Diesel is all I need
Nov 19, 2024
40
Texas
Ok so I got myself into a new project. Yikes didn't know how it would go. Swapped my 2005 Duramax 2500hd LLY diesel for a Duramax 2500hd LBZ diesel 2006 Cleaned my injectors swapped parts balanced my valves and swapped a lot of parts now getting ready to put back together. 3rd time working hopefully it will start. Wish me luck.
3,059
Welcome
What was wrong with the LLY? Also, some of those early LBZs where detuned to match the LLY output. If yours is like that you can install the later tunes and "restore" the power and still be fully EPA compliant
HDduramax
Nov 19, 2024
40
Texas
Welcome
Well yes a lot of parts did match. 1st time I put in the new one connected everything but knocking
2nd time did in fuel injectors.
Now 3rd time adjusted valves balanced and or got it to clear valve adjustment since it rained didn't worked on it but tomorrow ?? connecting the rest back oh yes I did replace rail pressure sensor, new fuel pump, fuel pressure pump, and replaced crankshaft sensors and the crankshaft sensor. New gas treatment new diesel fuel drained radiator new fluids, we shall see tomorrow any ideas I could be missing?
3,059
Double check the crank and cam sensors are in the right harness connector. Easy to accidentally swap them and you'll have a no start condition. The two sensors look the same and connect the same
Do you have a bidirectional scanner, like EFI live? Very helpful in diagnosing no start conditions and many other issues
By they way, Tom, or another mod will likely move this thread to another more appropriate location now that it's moved beyond an introduction
3,435
So you swapped the 06 LBZ/6 speed drivetrain into your 05 LLY truck? Remember to swap the cluster, shifter and pedal assembly?
And yep, moving this to repower/transplant section.
Cougar281
1,962
384
St Louis, MO
If this is what was done (06 drivetrain into an 05), and the ECM and TCM were swapped as well as required harnesses, it'll 'work' without the 06 cluster and shifter, and it would 'probably' start with the 05 pedal (I know with a similar gasser pedal that had the wrong voltages for the LBZ, it would start but there was no pedal input). Now, if a 06 LBZ drivetrain was dropped in but the 05 LLY electronics were left, that's a different story.
HDduramax
Nov 19, 2024
40
Texas
Awesome
HDduramax
Nov 19, 2024
40
Texas
Ok still working on this haven't tried to start it just yet yes I got new wiring harness actually not new from salvage yard tested me glow plugs tested my injectors looking at my timing to make sure they are lined up
HDduramax
Nov 19, 2024
40
Texas
BTW was curious about what year model engine I have how do I know what the correct engine code is
HDduramax
Nov 19, 2024
40
Texas
Yes I read into this awesome information thanks
HDduramax
Nov 19, 2024
40
Texas
Actually on the scanner on its way soon
HDduramax
Nov 19, 2024
40
Texas
Oh it's been fun so far but yes lots of swapping out here and there thanks for the information
1,623
So you got it running but it has a slight knock? Does it continue through out the RPM if you accelerate?
Did you get scanner yet?
HDduramax
Nov 19, 2024
40
Texas
No scanner yet but when accelerated yes it still knocked and replaced wiring harness that goes to the computer when wiggled it turned off the motor assuming it was a broken connection but still knocked
HDduramax
Nov 19, 2024
40
Texas
Hey y'all I did a engine swap replace a lot of the wiring harnesses now it won't turn over unless I spray starting fluid help how do I test it or I'm thinking maybe it's another wire that's not getting contact
HDduramax
Nov 19, 2024
40
Texas
Well the light that were flickering on the dash that was because of a ground I already fixed that but after that it's still not starting
