Tuned lly duramax no added power between tunes
shakenfake
Moron
Sep 15, 2022
417
202
Shlumpt, TX
Sounds like a classic GMT800 issue. I've never come across it but 03-05 trucks I am always hearing stories on how they don't like to take tunes and require the PCM/ECM pulled and benched.
993
There is a com wire connector under the dash near the I/P fuse box above and behind the park brake release called SP205. All the data wires for all the modules are tied together in that block with a jumper cap. It is, IIRC, a 2x6 connector with a white cap. If you pop that cap off and jump wires B and D, you basically just made a bench harness and isolated the ECM to the OBD2 port. I do this to every LLY and LB7 I flash now because almost all of them have some sort of aftermarket electronics gizmo that causes hell with flashing.
Tactical Camel
May 28, 2017
20
Mississippi
Thanks boss, I will give it a go today.
1,674
That only Applies to the Diesels.
The gassers never had that problem. You might have to pull a radio fuse with and aftermarket radio But Otherwise unless someone has done some major Electrical work It's usually a non issue. More often than not the 10 Amp Cigarette lighter fuse is blown and it won't communicate with the PCM. That's because the OBD2 port pulls it power off the Cigarette lighter circuit in these trucks.
1,674
That's a handy peace of info!!! Thank you!!!
shakenfake
Moron
Sep 15, 2022
417
202
Shlumpt, TX
Interesting, because I hear it all the time from gasser tuners lol
RDF1 on PT.net talks about it a lot. I had never even heard of it until the past couple years and now it seems like everyone knew this but me
1,674
I have never had the issue on a Gas truck With EFI Live. Usually an aftermarket radio will cause noise on the buss but once you pull the fuse its a non issue.
The only issue I ever had was on my 2000 it would reset the clock radio to 12:00 when the Flash was complete, and that truck was 100% stock.
Tactical Camel
May 28, 2017
20
Mississippi
Update: I done just like you said, it acted like it took the tune but again no change with the dsp5 switch, now i also have the anti theft light on, battery light on, oil pressure gauge doesn’t work and fuel gauge doesn’t work, also can’t read the pcm now. It all worked fine at first start up but after about a minute it done all that. I think I’m going to try to get another tune sent.
Can you read back the tune and see what it is?
Those errors will likely go away when you drive the truck as they were a result of being disconnected from the network
Tactical Camel
May 28, 2017
20
Mississippi
I drove it for about 10 minutes or so I unhooked the batteries and left them. And i’m not sure what you mean by that, I’m fairly new to tuning, only tuned about 10ish trucks.
Using the same tool you load the tune with. Read the tune out of the ECM and open the resulting file and compare it to the one you are trying to load into the ECM.
If the files are the same then you know the tune loaded correctly and it might be something in the tune itself that is not making apparent power changes and not the loading process.
If the files are different then you know it's the loading process that needs to be looked over
3,930
829
Maybe I missed it, but are you using a Flashscan? If its not an autocal I can send you a tune to try that I know 100% works
Tactical Camel
May 28, 2017
20
Mississippi
Yeah, i had my buddy i get tunes from use flashscan on it. We got another tune send yesterday evening, we are going to try it out soon.
8,236
Are you actually tuning or just getting your tunes from a tuner?
Tactical Camel
May 28, 2017
20
Mississippi
This sounds like an issue that you should work out with the tuner.
I think I might be on to something, I had previously done some work to this truck and it had bad batteries at the time so i had to pull the pcm fuse to reset it so it would run, i had this thing sitting for a few days and it needed to be reset again. I’m thinking the pcm may be bad.
