I was just digging for my custom LMM std trans bin, but don't see it on this PC. However I found a link to this other uncommon LMM version which may be of some help. I actually use the 4Lo wire in this version to control RPM and Torque limits based on grounding one pin. IE: Valet Mode, or Lo Gear Mode is how I use in stand alone setups.
www.duramaxdiesels.com
I'll keep digging for other LMM copy and the bit map to switch it. If can't find, I know who has it mapped. It's only 1 bit...
LMM (NQG) Tune VS Standard
As most of you know I prefer the E35B over the E35A ECM for stand alone swaps. And I thought I knew it pretty well, until I started looking to assign some normally unused signal lines for other uses. That's when I stumbled onto a pinnout difference between two build version under the same LMM...
