Nice work. Bad ass swap
Absolutely, I had efi live logging some cruise data the last run I made. I’ll definitely have to do more.Nice work.
Now ya need to hook up efilive and start logging some pids while ya play with the brake and P/N wires. All those important position values can be logged, along with VSS pulses and cruise related parameters live, which will then tell ya what mode the ECM is in.
I run the LMM's in stand alone with nothing connected to the P/N circuitry and not notice any torque limiting. Nor with a T42 wired up, until I hit the speed limiter conflict..
However, there is some gear related torque tables that might be coming into play, depending on what gear the TCM is telling the ECM it believes it's currently in. That would make sense with N pin overriding the CANbus data.
Be interesting to see what it thinks it's doing at 40mph or so. Need more data...
Just search SPEED in efi and will find multiples under ECM & TCM.Absolutely, I had efi live logging some cruise data the last run I made. I’ll definitely have to do more.
For the VSS pulses, I don’t see that parameter in efi, I’ll have to check hpt yet but if it’s not there either do you think it could be changed in the bin? If not I guess I could just change tire size to compensate, it’s off by a factor of 1.78 according to the dash.
You and me both lolJealous and happy to see it moving under it own power
That would be much appreciated, thank youI have a T42 tune file I ran on the boat for speedo only. Let me dig that up for ya.
Have you scaled it yet? To see how much the weight changed?You and me both lol
No I haven’t yet. Something I want to doHave you scaled it yet? To see how much the weight changed?
What kind of .bin work do you need exactly? I might be able to help.I spent some time and re wrote the tune for the car, previously i had been learning new things for the lml every week and i think that lead to the overall tune kinda being a mess.
So i started fresh, went through the timing calculator, referenced some other tunes to make sure i wasnt way out to lunch on timing. Then added fuel and air. I went from sloppy black smoke to a nice clean pull. And to my suprise it is not cutting out like before which i thought was the tcm pulling fuel.
But i have settled on something, this winter im gonna roll back the Ecm to a LMM. I have found a low km Lbz with good injectors. I'm tired of once in a while the lml immobilizer causes a few start/stops. And now with the tr6060 in place and working good ill be able ditch the tcm completely and setup the E35 as a manual transmission OS.
Ill be looking for someone to modify the .bin if that's something you can do please reach out.
Will need an Lmm file modified to run as a manual trans OS. A guy named Dillon had one done before. He said everything is in the Lmm bin just needs to be changed to be the same as an lbz manual. Then he said wire it like a lbz manual and it all works. He had converted a Lmm to zf6 and was able to retain speedo and clutch safety.What kind of .bin work do you need exactly? I might be able to help.
Ok, I would have to research what's involved. Might be beyond my skill level.Will need an Lmm file modified to run as a manual trans OS. A guy named Dillon had one done before. He said everything is in the Lmm bin just needs to be changed to be the same as an lbz manual. Then he said wire it like a lbz manual and it all works. He had converted a Lmm to zf6 and was able to retain speedo and clutch safety.
Well might aswell document trying to learn .bin editing. Here I’ve got two bin files. One manual and one auto lbz, they both went in efi live and all differences beside segments where matched. Looks like little over 1600 byte differences. I guess now I need to try define what exactly each is and then modify the auto file to match. But of course in a LMM. Next I’ll compare a LMM bin against the auto LBZ then hopefully the lines that are different between these two, the same lines in a LMM should match the auto LBZ ?? Feel free to tell me if I’m crazy.
