Everything is back together, but now a new problem as popped up. I am getting P0203 and P2149 (and sometimes P0202 and P0205). This wasn't happening when it was running before with the fuel leak. Just letting it idle it will happen between 10 minutes and 20 minutes of run time. Runs fine before it happens. I checked the resistance from the FICM connector to all the affected injectors and they are fine, and doesn't change when wiggling the pigtails. My current idea is that it seems unlikely there is some weird new issue going on with that pigtail or injector, and that I did find that my FICM, which had been sitting on a table outside under a carport, had the breather broken off and we have had a ton of nasty weather and humidity. Maybe something is wrong with my FICM?
So which pain in the ass course of action do you guys think is more likely to fix this? sending the FICM off or opening the valve cover again (to look for ???)
I'm starting to feel cursed.
