June 1st snuck up on me. Still thinking up a name for this month.
My AC has been on since late March.....Hey, no need to be excited for winter when we aren't even halfway through summer. There's still plenty of summer sports that need enjoying first.
But it's also crazy how fast it is going. This year needs to slow down already.
My AC has leaked off 24lbs of freon since March. Haven't been able to locate the leak with sniffer or dye. I'm down to thinking the neighbor's filling cans when I'm away... lolMy AC has been on since late March.....
24lbs? How big of a system do you have?My AC has leaked off 24lbs of freon since March. Haven't been able to locate the leak with sniffer or dye. I'm down to thinking the neighbor's filling cans when I'm away... lol
Really? We didnt switch the heat off until early May. Heck, I had to turn the furnace on a couple days this week.My AC has been on since late March.....
Yep, keep the place low 60s, grant AC did kick on at night when lows where in the 40s which made for mid 50s inside, add a fan and perfect sleeping ? ? ? ? ?Really? We didnt switch the heat off until early May. Heck, I had to turn the furnace on a couple days this week.
Gues including refills ??24lbs? How big of a system do you have?
Ooof... 24# of refrigerant is spendy.My AC has leaked off 24lbs of freon since March. Haven't been able to locate the leak with sniffer or dye. I'm down to thinking the neighbor's filling cans when I'm away... lol![]()
Like on 4th fillup already.Gues including refills![]()
Oooohhhh yeah, this one is 10" wide by 16" diameter and has a 2hp 3ph 220/440v motor on it.Those make good shop fans.
The A coil had been repaired a decade back, so I planned to replace it when we moved the compressor this spring. The tech I hired to move did a 400lb nitrogen test on it and went over the A coil with soapy water and found nothing. So we vacuumed it down and held it 30-40 minutes before charge.. Evaperated 12lbs in about 10 days in March April doing heat pump duties..Have you done a full pressure nitrogen test? Helped my friend diagnose a dehumidifier here that was losing charge, but no visible leak. It would only leak when operating at full pressure, but you couldn't hear/see it because of the fans moving air. Pumped it up to 450 PSI with nitrogen and soapy water found a cracked condenser.
Haven't had the AC on yet here either.Really? We didnt switch the heat off until early May. Heck, I had to turn the furnace on a couple days this week.
