I can see the simplicity of this but imop the factory filter is grossly inadequate on all Duramax models.
Working for Cat I got a real education on proper filtration with the C175 high pressure common rail fuel systems. I changed more Fuel pumps and injectors than I care to remember.... They went to 5 fuel filters, 2 water sep filters at the tank and 3 ultra high efficiency filters before the fuel pump. The fuel is looped through the 3 filters 12-13 times IIRC before it enters the high pressure fuel pump... It took that to get a fuel pump to live more than 5-6K hours.
Trust me you can't have to many fuel filters on your truck. I run a Cat water sep filter and the new High pressure common rail ultra high efficiency filter. I plan on adding another ultra high efficiency filter to that as well.
As far as the sump or draw straw, it's all in the care of the install and having the propwer tools. I have seen both leak from shoddy installs and both work perfectly when installed correctly.
Just my 2 cents.
