What area are you in up there?I used to years ago before my family moved up from LA
I'll have to take a look at the FICM to see where those extra wires for 6 & 7 go. But I only counted 8 driver mosfets that where connected to the injectors. Is it possible the larger wires where the injector supply voltage?
Folsom. Near Sacramento areaWhat area are you in up there?
Diagram is right from the 2003 and beyond electrical pdf. GM upfitter.com. so truly from GM. Not sure why people go to alldata or others for wiring when GM provides it all free.Anything is possible, but I was sure they weren't. I was using a connector pinout from Mitchell, where's that diagram from? Mitchell claims all the connector end views and pinouts are from GM
Don't think I have been much past Sacramento ever. I rarely go past SanFransico and thats mostly been for work.Folsom. Near Sacramento area
no problem. someone's got to have what we need.Don't think I have been much past Sacramento ever. I rarely go past SanFransico and thats mostly been for work.
I do... I have a SnapOn Verus too. Has a 4 Chanel lab scope on it. I just don't hardly use it any more an not sure what your trying to measure. But I would gladly make my self and truck available. I am sure I can talk my buddy into borrowing his as well if you wanted to verify on more than 1 truck. If I had an extra room I would offer it up as well. Best I could do is probably cash in my hotel points as I never use them anyway...no problem. someone's got to have what we need.
Tap into one of the ECM injector control lines and see what the signal looks like. Preferably under different driving conditions to see if there os any changes. You only need to tap into one line as I'm sure they will all be identical. Also measure the current on the two 12v supply lines to the FICMI do... I have a SnapOn Verus too. Has a 4 Chanel lab scope on it. I just don't hardly use it any more an not sure what your trying to measure. But I would gladly make my self and truck available. I am sure I can talk my buddy into borrowing his as well if you wanted to verify on more than 1 truck. If I had an extra room I would offer it up as well. Best I could do is probably cash in my hotel points as I never use them anyway...
Tell me what pinsTap into one of the ECM injector control lines and see what the signal looks like. Preferably under different driving conditions to see if there os any changes. You only need to tap into one line as I'm sure they will all be identical. Also measure the current on the two 12v supply lines to the FICM
Is this attachment for an LLY???
Yeah, GM seems to switch back and forth with the namingNever herd it called an EDU before.
There's another reason to drop the current once the injector is open. It lowers the strength of the magnetic field so when it turns off the weaker field will collapse quicker and shorten the delay making the on off time for the injector more accurate.I have access to Mitchell for free too, so it didn't really matter. But I'll compare when I get a chance to see if there is a difference.
From what I saw, both the power supply wires from the FICM run back to the fuse box and are actually spliced into the same spade on that 25a fuse.
If the FICM really does drop voltage after the injector opens, I wonder if the later models that are controlled by the ECM do this, and if it's really necessary with how short of time they are on? I imagine you could build a board to withstand constant power
