Gotta love an "inexpensive" repair...
I've never actually sprayed a diesel personally. However back in the 90s, I sprayed a hundred different gassers. NOS dealer for a decade, and beta tested the first progressive controller unit to hit the market.
My specialty was extremely well hidden street systems. Like direct port under the intake, 20# bottle in spare tire hole. Purge into the exhaust.
But those sneaky Pete on steroids style setups usually suffered failures due to trash in a fuel jet. Is hard to explain a hole in top of a piston, when your naturally asperated... lol fun times.
What I learned that's actually transferable to this discussion, direct port as close to the valve as you can get is your sweet spot. Equal distribution is key. Even in a diesel, pistons don't like a blow touch on em while their neighbor is a richer mixture. They all prefer to all be fueled and cooled equally.
I finally outgrew the low power plates and under intake stuff and went full stackded proshot foggers, on a tunnel ram with efi. Piston holes went away, even with 400-600hp shots. So maybe look at stacking some jetted nozzles shooting right down the pipes.. I do appreciate ghetto fogging for its simplicity.. lol
Bests
Skirt looks great from here, what was the piston clearance?
That's an interesting break on both of those....
How much spray were you running and what kind of power is putting down?
Did you pick up a new truck Rick?
