LML coolant issue
Dirtymax113
Dec 13, 2022
I’ve been trying to figure this out for the past 6 months. I have a 2011 sierra 2500 with the 6.6, and I’m have this weird issue with my coolant. Low coolant light comes on and I can see that the tank is about 3/4 full, never less than that regardless of how much I drive without topping it off. When I do top it off and drive it, it can go a while (2-3 days) without the low coolant warning pop up again.
I do notice though, when I do add more to the tank and drive enough to lower the level, some coolant is added to the overflow tank. Not a huge issue, seems it doing it’s job as the coolant expands due to the heat, but eventually the overflow will fill all the way up and start leaking out the drain hole. I’m not sure if the overflow is supposed to eventually empty back into the reservoir or what. I do notice when I unscrew the cap slowly while the truck is still hot, the level of the coolant will rise a good 1-2 inches in the reservoir tank, while the level in the overflow stays the same.
The upper radiator hose used to be really stiff, and stay that way overnight. Lead me to believe head gaskets went bad, but no other signs of HG were present… no oil in coolant, no coolant in oil, does not overheat, no blow-by or white smoke from tailpipe.
I started replacing all the cheaper stuff to see if those would Fix the issue, thermostats, hoses, reservoir cap and the radiator, but I had no luck. Then a couple weeks ago, I replaced the coolant tank itself. Since then the upper radiator hose doesn’t get as stiff as it used to get, and doesn’t hold pressure overnight anymore, but the same problem with low coolant in reservoir tank and too much coolant in overflow tank.
At this point I’m at an absolute loss, and can’t seem to find an answer anywhere online, and it’s getting quite frustrating. I appreciate all comments, and thank y’all in advance
4,847
1,894
To be fair, holding pressure in the system overnight is usually the #1 sign of bad head gaskets/crack somewhere (9 out of 10 times its HGs). I think I've only seen 2 mixing fluids come into out shop over the years, the rest were all hard rad hose.
Dirtymax113
Dec 13, 2022
But what confuses me is that it doesn’t do that anymore since I replaced my reservoir tank. Wouldn’t it continue to do that if HG were the problem?
4,847
1,894
Typically it would continue. My comment was to clarify that the typical data point of bad HGs is a hard upper rad hose.
What brand coolant tank did you put on the truck?
Dirtymax113
Dec 13, 2022
Dirtymax113
Dec 13, 2022
The truck is also deleted, idk if that would also cause any issues. It was like that when I bought it
juddski88
Freedom Diesel
Jul 1, 2008
4,659
130
Chesterfield, Mass.
You may now have a slight leak in the plumbing which is releasing the pressure, or the headgasket sealing area is now contracting enough when cold to release the pressure. Either way, a compression leak at the head gasket is a dynamic issue.
8,235
he wants to know the brand of the coolant TANK, not the coolant lol.
Also, you could very well have a brand new cap that is not holding pressure like the old one. Being that LML's are notorious for hg failures due to the junk design gm made, all signs still point to it my friend. You cant follow the typical signs for bad HG on a dmax.
Dirtymax113
Dec 13, 2022
Ohh haha, it’s a ACDelco tank. It seems to me I may just have to take it into a shop and have someone actually look at it and give me the yes or no from HG
5,101
703
Make sure it's a GOOD shop. You have time to find one. So you dont get screwed. You have pretty much done everything a shop would do to confirm you have bad HGs.
660catman
120
I agree with what all have said as I went through this last January. HG was the issue. I did find a GM mechanic who started his own business. His specialty is on Duramax engines. Everyone I talked to recommended to change the water pump too while your in there.
2013 Sierra SLE 2500HD Crew Cab
5,101
703
Aleast replace the stud with an Allen head bolt so the balancer doesn't have to come off.
But ya my water pump went out within days or weeks of me doing my HGs
TA2510
Jul 12, 2025
Louisiana
I also am having the same issues with my 2013 Sierra 3500 with the 6.6. The only difference between mine and yours is after i park mine for a couple hours my radiator hose is soft again. I can smell coolant under my hood and sometimes while im driving down the road. I just cant seem to find a leak.
3,587
Have you looked under the truck at the waterpump weep hole to see if there's any evidence of leakage from there? Usually that starts as a "pressure leak" while driving, not a "sitting leak", so you dont get a puddle under the truck over night. On the older trucks, there was also a coolant block off plate on the passenger side of the engine/transmission adapter (under the pass side up pipe) that would start to leak. Not sure if the LML still had that, but might be worth a look.
TA2510
Jul 12, 2025
Louisiana
I will check it out. Thank u
LML also has the issue where the rubber flaps around the fan shroud can invert and rub the radiator causing a leak. It can leak but not drip because it dries on the fins. Being on the fan side of the radiator makes it hard to see
TA2510
Jul 12, 2025
Louisiana
Thank you. I will look at that also.
