Best rotors
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
A customer of mine has managed to warp his OE and now Napa Fleet front rotors ive installed on his 2018. What have you guys found to hold up to aggressive brake users/towing? These trucks are known for this issue. Thought maybe Napa's Fleet stuff might have been the fix.....
8,051
put a proportioning valve on the fronts and lower the pressure? lol
is he a 2 foot driver? aftermarket wheels? doesnt know where the trubo brake button is?
SmokeShow
6,818
Lawrenceburg, KY
I hate to piggyback and know there are other brake threads but they've got some age on them so thought I'd poke in here....
in addition to best rotors... is there a "best that money can buy" brake setup for street use that includes better/bigger rotors, calipers (pistons), pads, etc?
1,862
Willwood is pretty much the only option there.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,758
526
P.N.W
The ones I seen from them, you have to have a 20" wheel diameter minimum.
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
Its a cc lb with aftermarket 20s but only 295/65 tire or so.
Ended up getting Adaptive One rotors thru napa. Slotted for the front. We will see
1,862
That's the only way to get larger rotors like you asked. There is not a kit that has larger rotors that does not require larger wheels because the space isn't there on a 16" wheel.
EBC makes killer pads/rotors for these trucks but you'll pay for em handsomely.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
Flush the brake fluid with Castrol SRF racing brake fluid. If they’re warping rotors their brake fluid is probably close to failure.
8,051
i was curious if the wheels are pretty blocking to air flow. its made a difference before
3,059
in my opinion it's a hit or miss on warping no matter who you get them from unless the manufacturing does normalizing between passes on the lath when machining them to size. cast steel is probably the most stable under varying temperatures but depending on the grain structure of the steel and how it's oriented even they can warp.
the only ones that wont warp are the carbon rotors that some air craft and race cars use. but they have there own set of different issues
I'd just put another set of stock rotors on and have them probably broken in with a new set of pads. oh, and teach him about that turbo brake thingy ?
08lmm72mm
544
169
Canada
I used to warp stock OE rotors until I switched to Powerstop xtreme brake and tow. Haven't had am issue since on 22s with 35s. I'm hard on my brakes.
pornstar dancin
pornstar dancin
Oct 23, 2012
251
almond ny
I put the powerstop kit on my 16 after warping the factory rotors hauling equipment. They seem to have more stopping power than factory and do very well with either hauling equipment or the pulling truck
Sent from my SM-A426U using Tapatalk
