there is no damn way id ever drive a school bus. i rode a bus that the kids make drivers quit before the school finally got the balls to kick them off it.
You have nothing to worry about as long as the temperatures are above 40 and not dropping. If it's below 40 you need to use insulated blankets to keep the heat in the concrete since concrete produces its own heat as cures. If you're pouring inside your building it might not be an issue since the concrete would probably raise the temperature of the building depending on how big it is. Or you could just pump some heat into it before the pour and it would hold the temperature long enough for the concrete to cure.View attachment 110960
My building is already up and closed in (windows and doors) just no insulation or heat.
na i never had the balls. i was too concerned with loosing my privliges to ride my quad if i was an asshole like that. i just sat there and watched the show.You were one of those guys huh? Sound like you where like my friends. Apparently according to the reprimands my mom showed my wife and me from my school. I was too busy making out in the back of the bus to get in on that.... ?
Thank you. Yes, we are pouring inside. Building is 40'x72'x16'. All doors and windows are installed.You have nothing to worry about as long as the temperatures are above 40 and not dropping. If it's below 40 you need to use insulated blankets to keep the heat in the concrete since concrete produces its own heat as cures. If you're pouring inside your building it might not be an issue since the concrete would probably raise the temperature of the building depending on how big it is. Or you could just pump some heat into it before the pour and it would hold the temperature long enough for the concrete to cure.
Ya winter has hit us too. Highs of a freezing 55*. I had to break out my hoodie....?6-8" of snow yesterday and last night. Yay.....
pics or it didnt happen6-8" of snow yesterday and last night. Yay.....
I forgot. You don't know what snow is.pics or it didnt happen
exactly!!! i like to see that stuff every so often, briefly feel bad for you guys, then go back to my 60* weather.I forgot. You don't know what snow is.
Happy Birthday, too!
Was there supposed to be a picture of the cracked manifold? What kind of truck and engine is this?so yesterday afternoon, decided to give Erins truck some love. needed an oil change, some interior parts fixed and fix an exhaust leak. i was hoping her truck had the steel tubular manifold on it as you could tell it was cracked.... nope. its was cast. Had a stud at the lower exhaust stud snap and found one was snapped at the head. pulled the manifold and half ass welded it back up to get her by till the new 600 dollar unit showed up ??. drilled out and re-tapped the one that snapped (couldnt get a welded nut to pull it out). put a new bolt in as a stud on the lower connection and started putting it back on. Snapped two studs off in the head... i was pissed.. threw it back together as is till tuesday.
cant be easy! least its not a V style engine. im already prepping to having to pull the head to get the damn bolts machined out if i cant get them ?
nope, no pic. bad sentence structure lol.Was there supposed to be a picture of the cracked manifold? What kind of truck and engine is this?
Ah that thing is light compared to a full size truck... send it!!!nope, no pic. bad sentence structure lol.
she has 3.7 I5. its an 08 canyon.
EDIT: they make a t3/t4 exhaust manifold for this truck and id be lieing if i didnt stare at that manifold for a while.... problem is, "4l60E"
noooo waaaaay. its got 135k on it and im just waiting for it to start adding neutrals.Ah that thing is light compared to a full size truck... send it!!!
I waited till 150K to put a cam in my 1500... It's almost 180K now and it didn't go neutralnoooo waaaaay. its got 135k on it and im just waiting for it to start adding neutrals.
im hoping it dies about the time i need to change the balance shaft chains out because, ya know, lets put those chains under the flexplate so you have to pull the trans to change them ?
if it was my truck, it would already be turboed and probably have a built 4l60 or 80 in it. BUT this things is the "reliable transportation" thats gotta get the kids and wife to work/school driving 45 min each way. its been a very good truck and i want to keep it that way. it is tuned thanks to @The Neens and i got 33's under it at stock height but thats about all she will get.I waited till 150K to put a cam in my 1500... It's almost 180K now and it didn't go neutral
