Damn I don’t update this thread for shit.
After the engine swap, the China turbo died… so I bought another
. Needed to make a ride we were doing so an Amazon emusa turbo went on. Old one died literally 4 days before our trip.
Between the last update and the turbo dieing, I scored on a montero transmission. It’s been the key to me being able to go driver side drop transfer case as it has the same output spline as a jeep yj/tj/xj trans. The extension housing adapter is also the same as a jeep so I can use new process t-cases.
That means I can go TTB up front (ford d44 twin traction beams off 83-95 bronco or f150). So of course I did just that. Picked up a full front frame section from a 93 bronco.
Pretty much sat while I acquired parts like brake pads, ttx ball joints, spicer u-joints, wheel bearings and seals, 5.13 gears, locker, carrier for the deeper gears, manual hubs, and other odds and ends.
Kept putting off working on it, preran the Cali 300 race with it, wheeling trips and so on. Then I was given no choice. We went on a cruise behind the house with my buddy who just recently got a Tacoma. Wanted to get him familiar with rock crawling. So all the hard stuff went good and when we hit dirt roads, I asked Erin if she would like to drive. She jumps in and we take off. Well she crests a hill at about 15-20mph and there is a hell of a wash out on the other side. I’m not paying attention and she’s to new at wheeling to look out the side of the rig as you crest steep stuff like that to look out for wash outs or other obstacles. It grabs the LF tires and pitched us 90* to the road. Everyone was good but tracker was hurt. Killed a seal in the steering rack so it pissed all its fluid out, tires were toed out big time and we were 40 miles from home.
Pic doesn’t do it justice but I was able to adjust the toe in to drive it straight. Couldn’t see what was damaged till we got home.
Found the knuckle was bent at the tie rod, spindle was starting to rip out of the knuckle and the steering steel mount were half broke off the frame. Sweet lol.
So then started the ttb conversion. First was swapping output shafts (montero trans is hydro controlled and mine is electronic), put the adapter on back of trans, get a jeep tcase, make Jeep tcase input shaft seal to montero output seal, and adapt everything over. This was tedious and time consuming.
So before I cut the front end out of it, I went and drove it to make sure I put the trans together right, things didn’t leak, I could adjust the Dakota digital to correct the speedo (jeep speed sensor reads twice as fast as the Suzuki), and just be sure this was going to work. Sure enough, test drive went good, had all 4 gears and tc lock up!
So out when the front end
And I’ve been working on getting the ttb in shape to put under the rig
Which brings us to today where I took today and tomorrow off to try to knock as much out as I can. Stripped the frame and started lining things. It fits decent. Oil pan keeps me from moving the frame back more but we are within 1” of my prior wheel base (I moved the old frame down 4” and forward 4”). I’ve still got room to move the frame up 1-2” which will help because as you see it is “ride height” and the ass end will go down 2 more inches than what the pic shows. I’d like to try to have this sit semi even but if it goes a little front high, that’s fine.
