Fuel pressure regulator
Duroman
71
I need a new one , Is there a brand that I need to look for ? I have seen them for 25 dollars and up
3,059
Genuine Bosch. the others have a track history of hunting and failing early. the proper ones are normally around the $120-$150 or so range.
Duroman
71
Thanks I wonder if you can answer this .My truck bounces back and forth on my mileage . Would this control that ?
Duroman
71
I have an issue with my truck for quite awhile now . during idle the engine goes up and down . Was told fuel pressure regulator . I decided to do a scan and came up with a P0089C . I looked it up and it didn't mention fuel pressure regulator . It mention my high pressure fuel pump and a fuel injection sensor or wiring . What are the thoughts on this and would this effect my fuel mileage ?
1,862
As stated, only use a genuine Bosch FPR/FCA/MPROP (pick your flavor to describe it). Poor FPR performance can cause losses in mileage, it can cause a P0089, it can cause idle surge like you're experiencing.
The Bosch PN is 0928400535, they're usually $120-$150 depending on the vendor etc (RockAuto usually is a good value for these).
Duroman
71
Thanks that what I was wondering
scott_willerscheidt
Jan 30, 2019
27
54
gig harbor wa.
Pay the money for the right parts or you'll regret it later guaranteed
2002 gmc sierra 2500hd quad cab short bed
Zone 3" kit
285/70/17 Nitto Terra Grapplers
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
HSP hot/cold side pipes
LED conversion
Edge CTS2 with SAS EGT probe
boost auto towing mirrors ( dual function)
fass 90
EFI live spade jack
dmax store stage 3 allison
