Fuel pressure regulator
Duroman
I need a new one , Is there a brand that I need to look for ? I have seen them for 25 dollars and up
1,723
Genuine Bosch. the others have a track history of hunting and failing early. the proper ones are normally around the $120-$150 or so range.
Reactions: BoiseRob
Duroman
Thanks I wonder if you can answer this .My truck bounces back and forth on my mileage . Would this control that ?
Duroman
I have an issue with my truck for quite awhile now . during idle the engine goes up and down . Was told fuel pressure regulator . I decided to do a scan and came up with a P0089C . I looked it up and it didn't mention fuel pressure regulator . It mention my high pressure fuel pump and a fuel injection sensor or wiring . What are the thoughts on this and would this effect my fuel mileage ?
Bdsankey
3,905
1,073
Neenah, Wisconsin
As stated, only use a genuine Bosch FPR/FCA/MPROP (pick your flavor to describe it). Poor FPR performance can cause losses in mileage, it can cause a P0089, it can cause idle surge like you're experiencing.
The Bosch PN is 0928400535, they're usually $120-$150 depending on the vendor etc (RockAuto usually is a good value for these).
Duroman
Thanks that what I was wondering
Reactions: Bdsankey
scott_willerscheidt
Jan 30, 2019
27
3
3
51
gig harbor wa.
Pay the money for the right parts or you'll regret it later guaranteed
2002 gmc sierra 2500hd quad cab short bed
Zone 3" kit
285/70/17 Nitto Terra Grapplers
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
HSP hot/cold side pipes
LED conversion
Edge CTS2 with SAS EGT probe
boost auto towing mirrors ( dual function)
fass 90
EFI live spade jack
dmax store stage 3 allison
