It was from the return next to the frpv. Nothing was coming out. I know that was to test the frpv. But now I’m trying to test the injector returns. I don’t have any adaptor to plug into the injector and don’t want to try to get hoses off the fittings currently on the injectors as I know they are brittle as this truck has 340,000 miles on ithow much fuel are you getting out of the returns? CP3, pressure relief and injectors? you said you did a bottle test. was that just on the injectors or something else?
Ran it to the hard line to the CP3. I believe I had the line to the fuel rail nipple to the jumper.so you tested the return coming out of the CP3? if so, and you didn't get anything then I go back to the CP3 is not getting any fuel or too much air. or perhaps the off chance of a bad CP3.
when you put the fuel jug on it, did you connect it right to the CP3 input or did you run it through the filter or FICM?
I will test the output of the return from the cp3 at the jumperso you tested the return coming out of the CP3? if so, and you didn't get anything then I go back to the CP3 is not getting any fuel or too much air. or perhaps the off chance of a bad CP3.
yesOriginal injectors?
I’m thinkin the same too but I’m not the kind to replace parts unless I find the exact issueWith 340,000miles i bet that's the issue.
I fabricated hoses to tap into left and right side return lines at the hoses into water bottles and driver side filled up quite a bit more than the left side
