New or Re-Build Steering Box
OleBlackyLBZ
353
86
My steering box is leaking. It has 287,000 miles on it, should I get a re-build kit for mine and replace all the seals? Or am I better off to just get a parts store replacement with a lifetime warranty. I have searched and searched and there dosent seem to be a good solution. Some even say replace it with a low mileage junkyard oem style. Do any of you have any personal experience with this before I start shelling out money. I wanna do this once and be done.
darkness
1,586
613
vegas
I put a PSC pump on my ‘07. While I didn’t have it long it was fine while I did. Sorry probably not much help lol.
OleBlackyLBZ
353
86
I just didn't know of there were other parts in there that would be worn out besides the seals with this many miles on it. If so I'd rather just replace the whole pump... if it's generally just the seals that go bad I'd like to try and re-build mine.
8,237
the vanes and body will wear over time. if the bushing/bearing is gone in the front and its leaking there, seals wont fix it.
ive heard tell that PSC has upped their game on their parts. i dont know if thats true but if so, id use one of their pumps. In your position, id buy new.
8,237
well if its the steering box, then lets go down a different road lol
if the box is still tight, reseal it. its a bitch to find a good tight box. i resealed my napa reman not long before i sold it. the kit didnt come with exactly the right seals but there was enough in there to seal up what it needed and put new sealing rings inside. @gmduramax would have to answer if its till dry or not.
Nate’s Dmax
231
66
Nappanee, Indiana
www.hooverauto.net
Yes you can tighten it up some. That PSC box is expensive i know but so far i have been very happy with it. I really think with the proper research you could figure out which gearbox they use to make that box. I’m not convinced they are custom making it but maybe they are.
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
No leaks but it has loosened a bit, nothing anyone would notice but it does have play now. I threw a red head on my moms LML and it is tightttt no issue so far but she doesn’t drive much
Yngdmax92
962
i have a friend who installed a psc box. has 30k plus on it. tight as can be on a lb7 with 12 wides at that. works great and so far it seems to be worth the money
4,850
1,899
We only use and install PSC boxes in these trucks. The PSC boxes seem to hold up the best in terms of tightness and the steering effort feels reduced compared to an OEM box.
993
84400715 bought this from Rock Auto for $290ish last month and installed it on an 08 dually.
