The single connector on side of the 7way. What is that?pop the cover off the fuse box and find the two studs for aux power and trailer brakes. you'll need to put the fuses in the appropriate location too. the wires should be labeled and tucked between the fuse box and fender if they are not already landed on the studs
That is for brake light only signal like if you had a camper shell with the center brake lightThe single connector on side of the 7way. What is that?
