7way connector found under bed
Vmyrhaug
2003 lb7sac45 35" 20x12 fjallasport flares
Mar 6, 2016
177
Norway
Can anybo confirm that this is the trailer connection wiring? Here in norway the dealer have connected euro style plug direct too the rear lamps.
20220102_225437-jpg.106718
Vmyrhaug
Mar 6, 2016
177
Norway
It did have this wiring connected. With a single connector on the side.
Vmyrhaug
Mar 6, 2016
177
Norway
Nice:) is there seperate fuses in front for this wiring? The battery + wire, is it direkt too battery or a large fuse?
3,059
pop the cover off the fuse box and find the two studs for aux power and trailer brakes. you'll need to put the fuses in the appropriate location too. the wires should be labeled and tucked between the fuse box and fender if they are not already landed on the studs
Vmyrhaug
Mar 6, 2016
177
Norway
The single connector on side of the 7way. What is that?
dndj
Boost!
Apr 13, 2019
302
Oregon
Stud #1 is a 40 amp cartridge style fuse which feeds the +12v wire in the 7 way trailer connector. Wasn't populated from the factory on mine, but once plugged in, this is a direct connection to the battery.
Stud #2 is a 30 amp cartridge style fuse that feeds battery power to the relay block (interior, by the driver's left foot) where the brake controller harness plugs in. Supplies the +12v to the brake controller, which in turn provides electric brake power in the 7 way trailer connector.
