Banks DataMonster or Edge CTS2
3,905
1,074
Neenah, Wisconsin
I’m confused at why you’d want to swap an LBZ into your LLY just to use a banks datalogger. You can use the banks as a stand-alone logger that will record only the sensors that are wired in. You could easily add rail pressure, MAF, pedal % by tapping into those 5v reference lines.
The hard ones would be demanded rail, timing, injection duration etc but they would be very easy to correlate two logs via APP.
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
You are probably right... I do have an LBZ as a spare still not worth going through that trouble. Other reason for me to consider the banks gauges is because my Aeroforce Interceptors are aging and one display has lost its contrast.
3,905
1,074
Neenah, Wisconsin
I've looked at getting the aeroforce interceptor gauges, the seem like a nice product. If you've been happy with them why not buy another?
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
I saw that they also do display repair...this is what I will probably be doing. The reason I wanted to switch to the banks is because of the bigger color display. I am not sure if they still sell gauges for the <06 Silverado, at least they do not list them.
3,905
1,074
Neenah, Wisconsin
Banks currently, in their iDash 1.8 line, does not support ECM data from anything before LBZ (on the duramax side). LBZ and up has some PIDs but @coker6365 would have to shed some light on what those PIDs were for his 2006.
MarkBroviak
DMax Junkie
May 25, 2008
2,075
360
Danville Indiana
I can tell you not very many at all! That's why I moved mine to my wife's 08LMM because it had more data displayed. I don't like the fact that some of the important pids the data isn't correct either like map sensor.
rmallen30
861
15
hillsboro ohio
I know there’s a ton of missing info on the lm2 platform on my wife’s Tahoe , I even called to verify before hand and they said all the info was covered , come to find out a lot of stuff changed on the computer side between the 20 lm2 truck platform and the 21 Truck suv platform. All I really wanted was to monitor regen and soot so she would know when it was in regen and those pid’s are not supported yet
