Lost the motor?
3,590
IMO, you wrecked the engine. Sorry. Might be able to salvage something from it, but expect the worst.....
A cracked piston wouldn't put coolant in the oil. A rod smacking the block will. If I was a betting man your long block is destroyed.
yeah, I was kinda thinking about that too but had already pushed the post button
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
yeah I am. im basically just hoping the drivers side head is good, and the crank. Now ive got to decide if i want to piece together a motor from a new block and rods, pistons ect. or if i get a reman. This engine has 83K on it, so If the crank is ok Id like to use it.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
Ouch!
yup, like zerogravity said. over-revving it floats the valves. you can either pop the keepers off doing that and drop a valve or if its bad enough, the piston hits the valve, bends the stem, breaks the head off and the valve head kills the piston, head, etc.
compression test aint worth it now lol
Agreed, I bet you floated a valve which took out the head and piston. When I lost my piston I just had a rough idle and was burning oil. Sadly valvetrain upgrade are over looked on most stock bottom ends.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
A question for you piston experts in the mean time. Does anyone have a good sxs picture of a stock vs delipped piston? I'm starting to wonder if the main difference between mahle factory and performance piston is just that. I have 2 lathes I use for my welding/ machine repair business. I'm sure I could manage to delip them myself.
bimmer95
86
Morgantown Pennsylvania
No there's more to the performance cast pistons then delipped. It's a different piston. I have delipped a few sets of oem an mahle oem replacements on my lathe, it's easy enough just takes some time. Open the bowl to around 2.5 inches and smooth out the sharp edges.
Sent from my SM-G981U using Tapatalk
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Yeah after I posted that I watched mahles video comparing the two. I'll probably go with a factory set and delip them. I don't need a high horsepower capable engine. Just a good towing one, and one that can handle 600-700hp of short street sprints. I'll probably start a thread in the engine building section next.
8,237
do not buy the mahle OE replacement pistons. they are known to be weaker than a set of GM lb7 pistons. if you are going the stock route, buy LB7 pistons from GM and delip them. otherwise id pony up and buy a set of mahle race cast. if you are staying on stock injectors, you are still going to run the risk of cracking them. only fingers pistons would be trustworthy enough to handle high pulse width, high timing stock injectors. if you keep your pulse width down under the 1500uS area, race cast will be fine for the hp you want. beyond 1500uS is deminishing returns anyhow in relation to engine health
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Gotcha. I'm actually looking into a local engine with 113k. If the motor is in good shape when I tear it down, I'd probably use those pistons and delip them. I'll probably dig into this deeper with you guys once I tear my engine down and start a build thread to ask you guys different directions to go. I'm not really in a hurry. This truck gets about 1500-2000 per year put in it. I have the time to build an engine.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
I have time, but my budget is pretty limited. I don't have a lot to spend on it, and I don't plan to borrow any money for it.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thoughts on a 2002 fully dressed engine with 170k for 2500? what would be the chances the block wouldnt need any attention? even if it would need attention, is it a good way to go to start a new foundation for another engine? there is one on market place about 2 hours away.
3,590
Well, I'll give you one thing....when you do something, you sure do it right....yowch.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
So actually, not as bad as I thought. Block and head is totally destroyed. But, drivers head is fine, along with I'm pretty sure the crank and cam. The piston exploded. I did not drop a valve. The stems are still in the head. Far as I'm guessing, the piston was weak or cracked and the high rpms from forgetting to put it in drive finished it off. A shame. The engine was in great shape. Good crosshatch in all cylinders.
ZeroGravity58
1,427
56
Maryland
What do the valves look like in the #5 bore where the piston let go? I'm not saying it can't happen but I've never seen a piston explode for no reason. I still suspect valve to piston contact. I also wouldn't reuse anything out of the bottom end of that motor. It's not worth it at this point.
3,590
Why wouldn't you use the crank and the cam if they look good?
Because according to that head, those piston pieces went all thru the engine. I wouldnt use any internal parts from that engine.
.....and it looks like you dropped two valves which killed that piston, not the other way around.
