Squeal on acceleration
DAKOTAKIDD
59
Hey guys. Recently I had the head gaskets done and egr delete with new pipes and no block plates. When I first got the truck back, there was no noise. Then after a good hill climb with a good load it now squeals when I accelerate. I had it back to the shop and they can’t find it yet. It only happens generally at low boost situation and it’s not as noticeable in higher boost situations.
The shop thinks it the turbo but I am wondering what else i could check before I buy the turbo.
Any ideas are appreciated
Truck is a 2005 LLY CCSB
Thx
DAKOTAKIDD
59
They said they looked and everything was good. Told me it was the turbo. The vanes are sticking.
DAKOTAKIDD
59
Sorry for the stupid question but what’s a drive pressure leak? Never heard of it before.
3,422
A leak in the exhaust before the turbo. Uppipes or manifolds. Its called "drive pressure" because thats what is driving the turbo.
I also think its an uppipe gasket leak.
DAKOTAKIDD
59
The shop pressure tested the intercooler for leaks and she is tight.
I’m not sure what’s going on here yet.
8,057
Doubt it’s turbo. As stated, most likely a drivepressure leak. The shop should pop the up pipes off and look at the gaskets for soot tracing (leaks will have soot all over the gasket). Depending on the gaskets they used, I wouldn’t be surprised if brand new gaskets were leaking
DAKOTAKIDD
59
Is there a better gasket or something that should be there instead of the gaskets they used ??
Pure Diesel
986
296
Ventura County
Did you supply the parts or did they? If they did and this has a warranty, I would put it all on them. If you supplied the parts and they only supplied the labor you have to find out whether they installed it correctly or it's the product.
DAKOTAKIDD
59
They supplied all the parts. They said they wanted it to get worse so they could find it. Right now they can’t find anything. I’m gonna look myself first for a blown or incorrectly installed up pipe gasket. I do believe they are meant to be installed a certain way. Is that right?
DAKOTAKIDD
59
Had a quick look tonight and the driver manifold most aft bolt/nut is not right against the manifold and I believe the black is exhaust soot. What your thoughts.
13,862
966
Maybe I’m blind, but I don’t see any signs of soot in that picture. What I do see is incorrect up pipe bolts. They should have a 12mm 12 point head, and those are clearly 6 point bolts.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
You can't get the 12pt bolts from dealer anymore. They only sell the 6pt like the newer lmls have. You know the ones that come prestripped......
13,862
966
Yeah, but those bolts sure don't look new to me.
