Sorry if this was answered already, this is a super long thread, but how many long bolts required for the retrofit?
I editted my post with the part numbers and added quantities to the bolts.Sorry if this was answered already, this is a super long thread, but how many long bolts required for the retrofit?
So I am getting close to installing my 17-19 cooler on my LBZ. Since I have a Kennedy lift pump I need to pull the one plug for the oil pressure switch. It has the same 1/2" NPT plug as the LBZ. I see mentions of the plug being metric and was wondering if that was only for the 2020 cooler ?
Thank you. The peanut rolling around in my head was starting to overthink it.It’s only for the 2020 cooler. 17-19 is still npt
I finally got around to Installing the 2020 oil cooler on my LMM. It wasn’t as easy as I thought. It’s just a very tight space especially with the 4x4. One thing that never came up is that the LMM’s heater core is connected to the elbow on the oil cooler. I am going to have to plumb a new return into maybe the top radiator hose or something because the 2020 elbow does not account for this. Not really a big deal. I installed the Setrab sandwich plate and the fluidyne cooler with -12 lines. All seems to be working well. I guess time will tell. Now I have I real towing machine! Don’t forget to relocate the grounding strap from the metal heater core line if you do this on a LMM, it was throwing my gauges off a bit without it. Hope this helps
www.duramaxdiesels.com
This is where I ended up putting my sensor, I used the glowshift m12-1.5 to 1/8 NTP adaptor and put a oring and thread sealer on it.
No, I just rolled under the truck, and it's dry.Has this leaked on you yet? If not that's the route I'll be going.
The 2020 fits with profab, I would guess it does with ppe. I’ll be checking my 2020 cooler with PPE style manifolds once my short block comes back.
Let me know, I have a sandwich adaptor for an external cooler that’s why I went with the 17-19 style.
So the 2020 cooler will work with PPE manifolds and up pipes? Gonna get one for my LBZ, just wanted to confirm again. Thanks fellasI used the setrab sandwich plate.View attachment 106054
Yep. That picture above is everything installed. PPE manifolds, 2020 oil cooler, and Setrab sandwich adapter. It’s actually great because now when you change the filter the oil can drip straight in the pan instead of the 4wd drive line.. also easier to get to.So the 2020 cooler will work with PPE manifolds and up pipes? Gonna get one for my LBZ, just wanted to confirm again. Thanks fellas
