I am thinking that they did a touch and go at the airport and just tossed it off the back door.
This is an LML block with a 2020 L5P oil Cooler being built as an LBZ so already a bastard child. What I am looking at now is an LML oil pump. If I change the front cover oil pump and gear then use a LML damper will it all work??? Or would I also need a CP4 to CP3 conversion???
I guess all I am asking is how much would have to change to use the LML oil pump?
Thank you. I have had trouble finding a local machine shop to line bore and decided to send it to SoCal for this. I will give SoCal a call to see if they have finished their LML oil pump convertion.
I may be ordering a new pan upper and lower as well as front and rear covers. If I get all these parts in LML is the damper the only thing that will need alterations? BTW something else to consider the girdle I am using is LML dose this dictate using an LML upper and lower pan?
Not sure what you are asking? I am not having any trouble getting anything. The question at hand is what parts interchange between LML and LBZ specifically making the LML oil pump work.Are they just out of stock or what? When I spoke to them last year, They had something like 50 sets assembled.
Now I don't even see them listed anywhere.
(Part# 79029) 2001-2004 LB7
(Part# 79059) 2004.5-2005 LLY
(Part# 79089) 2006-2010 LBZ/LMM
(Part# 79119) 2011-2015 LML
Edelbrock Duramax heads is what I was referring to. Those are the associated part number for each style engine.Not sure what you are asking? I am not having any trouble getting anything. The question at hand is what parts interchange between LML and LBZ specifically making the LML oil pump work.
You stated they hadn't been released yet. They were out last year and they had stock at one point.
Now I see they have removed the other part numbers and only show LB7 and LML applications. Some websites states say to call for availability for LLY, LBZ, LMM applications. I believe some one on here had a set of heads for either an LLY or LBZ application.
Interesting... When I spoke to the rep he claimed they did at the time have them in stock in Torrance. I specifically asked because I wanted LBZ castings. They Use 1 casting and Machine as needed for each application is what I was told. I was told you could get them Bare with no Hardware. But he said I would have to call them to see if they had any Bare sets because all the stocked inventory was already assembled.My vendors have never received stock of the LLY/LBZ/LMM head and only received the LB7 and LML heads. Edelebrock did release the PNs but I don't know if they ever released stock of them.
the web address is showing for LB7 @1FastBrick
You are correct!!!
I retracted my previous post. I need a SMH smiley... or a Hommer DOH smilley
Apparently I need my EYE's checked too...
