How long has it been since PPE started using a new routing ?
What did you do with the trailer wiring when you did this?
Yeah it looks like you use self tappers in it.
I brought this up to Cole (owner of BHP) and he said that was their solution. I personally am not a fan of it but it works. Mine is zip-tied under the truck out of the way, I cut it off the factory hitch.
Do you use the factory 7 pin or do you have a 4/7 pin?
Factory 7.
You also can get a generic replacement end for a GM from etrailer that is 4/7 and comes with a generic bracket.
Wander if the plugs are any different?
On etrailer? No, they are direct fit to your model year in regards to plugging into the factory wiring. You may want to go check them out.
FYI, I used the HM40975 from E-trailer when I installed my curt hitch. Maybe it will give you some ideas?
Got a picture of yours?
I’ll try to grab one tonight.
Don’t know if i can post it though.
Text them to me, Joe, I’ll throw them up. For that matter, I can probably hook you up with what you need if you send me the pictures.
