Man that thing is sweet! :thumb::thumb:
Yep...
Going to track today...![]()
I forgot about this thread. I built the top end with BTR stuff, added a stage 3 boost cam, no more AFM or DOD, got 105 ID injectors, pinned the crank pulley, did a few oiling upgrades and retuned it for 14lbs. Truck spun really bad on the rollers so I played with it at the track a little. No launch just flat footed it from a 700 rpm dig and it went 12.5 at 110 weight is over 5300. Tuner figures power is a tad over 800 crank with performance numbers and fuel trims. It's a blast to drive, I have put over 20k on it this year alone.![]()
NA 5.3 with mods would make 450HPish at the crank, 14psi of boost with the parasitic loss of the supercharger should around 300-350HP gain, then 20% powertrain loss should put you around 575-625 Wheel HP.Yep, your right, a 5.3 at 14lbs of boost with heads, kooks and high flow y pipe makes 550...:rofl:
