DSP5 haters discussion/argument/fight/etc
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,152
Wilmington NC
www.mydieseladdiction.com
Looks like he already offers soft tuning and switch already.
Because SOTF is nothing more than an electronic throttle stop that taps into a sensor circuit that he can use as a fuel limiter based on voltage. It is nothing at all like DSP5 from EFI Live where there are actually separate tables for all of the key things in the tuning to completely change how the truck runs at any and all throttle positions. Hell, if you know what the limiting table in the stock tune looks like for the sensor you at tapping into you can set up a switch with resistors to hit voltage set points and limit fuel to what you want, even on a stock tune.
Chavez91
People Go Outside?
May 30, 2012
139
Heh. Wouldn't you like to know
:secret:
Let's just say that something better than that FAKE switchable is coming soon.... Because with these fuel temp limit styles, you might as well just run a single tune. :roflmao:
:popcorn:
Isn’t the lml sotf done a similar way and not a true dsp5 like the older trucks?
13,862
966
Yes. That's why I don't push switches on an LML. I actually don't push switches on anything. I prefer single tunes.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
I’m the same way. Everyone wants a DSP5. Do people just drive WOT everywhere? Use your foot for how much power you want.
3,059
2x
On my LB7 I had the DSP5, only because it was my first Duramax to tune. All the tunes where the same PW and throttle tables. I used it to test various timing, fuel pressure etc.
With my LMM I stuck to just a single tune. And like above, I switch tunes with my foot. It does take longer to test changes, I have about a hundred saved versions so far, but I like not having any obvious switches or tuning done.
"One tune to rule them all"
8,051
the ONLY time i could see a switch is a DSP2 for turbo brake or not for towing. Otherwise a single tune can do it all when you put the time in and to build it right. You definitely start to see why the maps GM built for a stock truck look the way they do :roflmao:
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
I don’t even need it for the turbo brake, I just don’t let it come on till 2200rpm I’ll let the truck down shift before it comes on.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
I actually like the dsp5 in the 05’. I dick around with the tuning and test it on the track. Easier just to switch the knob then flash the truck every pass. Big power guys can use diff tunes based on what the track will hold for power.
Everyday driving I’m in the big tune, to not piss the trans off to much.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
No really. That's where throttle comes into play. It's not a light switch. Only thing Iike my dsp5 for is index classes.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Really, the throttle isn’t a light switch? Thanks for heads up.
My truck only runs 12’s so I wouldn’t know about having to much power. Are you really comparing your stripped down single cab to a ccsb street truck?
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
No problems here with a 1000hp daily driver, learn to use your right foot
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Mine only runs 9s. Stripped down race truck? What are you smoking? Still has a full box with line x and tailgate. Weighs 6000 pounds. Now instead of being a douche maybe learn something. When we have traction issues we leave at less rpms and roll into the throttle sooner. With doing 1.47 60ft with a 6000 pound truck at a crappy track i think we are on to something.
3,781
355
I can see the argument for a DSP at the track to just automate that process. Nothing wrong with wanting to make the computer do the work for you, IMO.
That said, I'm a big fan of the "one tune to rule them all" for street use. I haven't used my DSP2 switch in 8 years. Not even sure I have a DSP2 OS loaded.
I like the dsp due to the fast weather changes up here and the fact that I’m always towing heavy or cruising daily so it’s easier to just switch.
If I lived somewhere where the climate didn’t change from 90 degrees and sunny to 20 degrees and snowing in just a 3 hr drive as it sometimes can here I could probably get away with one tune for summer and one for winter. You lower lower 48 guys got it good in that dept lol.
