Can they be cleaned after sitting for an extended time?
After I hectors sit for a time period the fuel causes a sludge inside the body. Then exergy will not touch them. You could how ever try to use the nozzles on your stock bodies.
Not sure. Just what exergy told me. Not sure if there really is a way other than not letting them sit.
I was told a cp3 pump will do the same.
If you were not getting a proper connection on just one injector, it will shut down a group of 4. The injectors are separated into two groups of 4 in the wiring. That combined with the fact that they needed primed could lead to the no start. I'm not sure if it would bring up the circuit codes until you got it to run either. Even if the fuel system was primed and had ran before, it still would hard start with the circuit issue.Well this guy is a ****. Refusing to refund my money because they are installed in my truck and they are no longer in the coniditon he sent them. Also when i got the injectors from the guy i opened the package and was in disbelief how carelessly he packaged them. all 8 injectors were laying together with a few blue shop rags wrapped around them, the injectors were not tight in the package they were flopping all around. Because of that one of the injector electrical connectors were damaged. He had insured the package with usps for 2,000 and is saying i need to get my money from usps. The other 7 injectors still dont work is my argument, regardless if one was damaged because of his poor packaging, the other 7 should work and even the dmaged connector one should work if he sold me working connectors.
