Going for tens in the zf. (Mission Accomplished!!!)
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
What table is that? And I take it you are using this with the BD limiter?
Yes I am. Allows me to set my launch at any RPM I want. And as James already stated it's the "throttle base injection quantity table".
On an automatic you want to set it up differently so the RPMs stay smooth. Basically the RPM column at or below what you want you use a mm3 value a little above what it takes to run those RPMs while stalled against the converter, then the next column up you have to play with to get it to maintain RPMs smoothly. But a rough starting point is 10-20 mm3 below whatever it takes for your setup to maintain that RPM.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I just need it to go bap bap bap and build boost, what you guys are saying is Chinese to me lmao. I'm understanding the concept but I'll have to get with mark on this.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
How far down the track is your first shift? What about making a dsp5 switch that changes off of what gear your in and a momentary switch? You could ramp in the power, rev limiter, and other changes without you having to mess will the dsp5 switch.
zf>allison
Apr 30, 2013
3,394
elsberry mo
How far down the track is your first shift? What about making a dsp5 switch that changes off of what gear your in and a monitary switch? You could ramp in the power, rev limiter, and other changes without you having to mess will the dsp5 switch.
I know I have totally messed up my first shift and still had killer 60 foots, is say before the 330 though for sure.
5,088
683
A monetary switch is a switch that is only on/off while your fingers holding it down.
zf>allison
Apr 30, 2013
3,394
elsberry mo
I'm gonna see how she does with this setup going for a 10, then I'm probably gonna spray it next year. Every time I try to think of ways to build boost on the line or anything like that I always just go back to the idea of spray. If I do that i might upgrade to a bigger charger and see what the high rpm stock lly can take.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Started a new thread on comp d. Not sure how to post pics there. Just opened up my valair street triple thing looks beast.
