LML oil pump conversion info....
1,517
Mellings pump gears are taller and little bigger diameter than OEM
Aluminum has to be thick to yield same strength as steel.. making the pump out of cast iron means you can thin the walls out without sacrificing wall strength thus increasing ports for bigger gears and flow.
If orfice remains the same and flow is increase.. direct result pressure increases as well... pressure is directly corisponding to restriction.
He said he had it apart and everything was the same.
WVRigrat05
French Creek, West Virginia
That's pretty good info, I've been planning a build for when the time comes and I still scratch my head over an oil pump, I've always put a different pump in the gassers I had done, usually a high volume pump with the oil filter bypass blocked off, and never an issue, but seems like on the duramax a stock LB7/LLY pump with maybe a little stiffer return spring.
1,517
Will do.. when I get back home... As for max psi I hit 85-90# with 32° oil temp.
IDK which is lifting internal bypass or relief valve on the block
Both OEM pumps and the melling are left hand threaded version
1,517
At what RPM Reger? I'm 60-70@2000 with worn bearings and aux oil cooler
28-32@750 idle
With a 316 pump
Main and rod bearings clearance was .0025" avg
The LBZ/LMM pumps was 45-50@2000 and low 20s at idle
rcr1978
793
Spring Creek, NV
I thought I remember hearing the LB7 lifters had a additional lube hole for the roller on the lifter and the LBZ/LMM do not so if that's the case theres a lot less internal leaks on the LBZ/LMM.
Edit: LLY lifters may also be different from LB7
8,244
im still on my old stock pump with 213k. oil clearances were a bit more than Adams at .0026 to .0028. at 2100rpm and oil temps at 190 i see 65psi down the highway. this is still reading at the 01-02 oil pressure spot which guys seem to think reads higher than the 03-up. Idle at same temp its 25-30psi.
when oil temp starts going over 210, pressure starts dropping though. 240* at 2100rpm leaves me at 50ish psi.
kidturbo
Piston Tester
Jul 21, 2010
2,816
1,811
Somewhere On The Ohio
www.marinemods.us
We stiffened the internal spring on a stock LLY pump that I drilled squirters on some years ago. It always read 60-70 on the Autometer and ECM pressure gauge above idle. Then I saw an LML pump, there is no comparison.
We decided to use LML pumps with LBZ med duty pans and front covers on the twin marine build. Had to shave part of the pump case down about .150, and then take a good bit off the threaded / geared input shaft. That got us inside the LBZ/LMM front covers. Upper pan needs a touch of dremel work too, but they fit :)
LML gears are a good bit thicker than earlier models, reason for the conflict. But the feed tube is also about 30% larger, so makes a worth while mod IMO.
P.S.. If using LML blocks, only the #4 hole has the new thread to match LML sensor. If you wanta keep your LB7/LLY/LBZ/LMM sensor, just move up a hole or two where the threads are same as all other models.
kidturbo
Piston Tester
Jul 21, 2010
2,816
1,811
www.marinemods.us
Here is a couple pics I found of an LML pump apart. On left LML gear, notice the longer shaft.
Also the pump clearance to front cover wasn't main reason we machined housing. Could have just notched the cover. After thinking we had it whipped, the LB7 cam gear we used hit pump on final assembly if I remember correctly. Will post a pic of housing machine area if I can find one.
rcr1978
793
Spring Creek, NV
LB7 and Melling m316
LB7 and Melling gears are the same tried both sets in each housing.
Dia 26mm
Width 13mm
Shaft 19.95mm
I have pics of them will have upload later.
Also whoever has a Melling lay a strait edge across the back and see if it's recessed across the shaft area mine is not sure if it was intended to be machined that way or mines a pos.
rcr1978
793
Spring Creek, NV
Relief valve pressures
Stock LB7 pump pops the seat at 55-56 psi
Melling 68psi
Now this is a air check and it is at the point it just cracks off the seat the releif port is not physically open much just enough to leak air, I have no idea what it would be with fluid pressure to actually be open enough to blead off a decent amount off fluid but should be close.
