Yeeeeeea so....
Installing my dsp switch and putting the power wire (red) wire in the ecim plug hole and it didn't seem as it was sitting just right so I (carefully) pulled it back out and the clip part of the red wire was missing on the wire (connector) needless to say the clip is lodged in the hole I ground down a very small screw driver to push it up from the back side the driver went through but the piece must be lodged in a groove needles to say I thought o well I'll just use the black wire pin.....yea that would be great if the piece wasent lodged in where the pin has to click in so I stripped the red wire and folded the wire in half and ran it though the pin hole and it made it out the other side to make (connection) now my problem is it only makes a solid connection if I move the harness so being said I now have connection but it's not stable. ANY Ideas would be great short of splicing new Ecim plug on
