Yep. A load range E tire is good to a maximum pressure of 80 psi, load range D is good to 65 psi, C is 40 (I think, haven't bought any load range C tires for a long time), and XL tires are good to 50 psi. Tire weight ratings come from their size and load range. A 265/75R16 tire will have the highest load rating in load range E followed by D, XL, and C respectively. However, as you add more volume and contact patch to the tire, the weight rating goes up, so a 285/75R16 in load range D would probably have a higher weight rating than a 265/75R16 in a load range E just like the 305/50R20 does in the XL rated tire.And have a higher weight capacity than one 245/75/16 E range tires
The 315/70/17 I have are D range and have a 3119lb rating
Hell the 225/70/19.5 F have a 3640lb rating which is less than a 285/75/16 E range that has 3750lb rating
Your winter tires must not have been losing air. If a tire gets low, it heats up faster and makes the tire weaker. I'm sure the roads are also hotter right now than they are when you run your winter tires which doesn't help the tire any either.This scares me because ive had plenty of nails in my winter tires that ive left in for weeks and its never cause a blow out like that. Coincidence maybe? Or like stated they are the correct load range
That's more of a CYA legal/insurance thing than it is some sort of law. Tire stores are stupid about this in my opinion. If a tire meets or exceeds the weight rating of the stock tire, I see no reason why they shouldn't mount it on your wheel.Well regardless 4 different big chain tire places refused so it's obviously a common trend
Think about the lawsuit part of this equasion. If there was an accident the tire store would get nailed pretty bad. Why in the hell would they take that chance?
don't drive with known tire issues period! wtf.... your life or someone else's life is worth more than the few dollars to get a flat repair
I'm with this dude.
If I had to drive home with a tire I knew had a nail or was leaking (Which I have) I'd be limping it home, not doing 70 on the highway.
and you commented that you've around for weeks with a nail in your winter tires? That's like wiping your ass before you shit- doesn't make any sense!
I'm with this dude.
Thanks dad
Discount Tire refused to remount the wheels/tires on my younger brother's 2006 LBZ last year unless they removed the 2" spacers,(they told him when they removed the wheel/tire) talk about CYA...
To get around the issue of them not wanting to mount tires, I took the wheels and new tires there separately and had them mount them, they can't be liable for what they don't know.
