Digmax
289
Ha how many times have you checked your oil today??? Lol I'm assuming you've been on rd today?
Sent from my C811 4G using Tapatalk
1,456
Fill up.. i dont burn oil that fast..
Truck hates heat and high dew points been low 70°s
Grossing 28,000lb and cant climb a 5% grade at 60mph dropped into 4th.. :mad:
normal i hit the bottom at 60 and crest at 60
First tank did 9.7mpg with alot of idling
Just did full reflash of the ECM.. forgot to check for codes that dont pop the CEL.
Said loads
Fingers
Village Idiot
1,735
142
White Oak, PA
IMO, that was probably your problem in the first place. Not that the rest wasn't creeping up on you for later down the road.
If you want to play with your truck's parts, and make money with it, you need to keep some spares. I do for the engine anyway.
Short Block
Spare heads
Spare injector set
Spare turbo
Full gasket Set
Spare CP3
Spare ECM​
All are stock, but will get me back on the road in a pinch.
What I don't have, is a spare transmission, but I haven't played with that for over 10 years now.
1,456
Short Block
Spare heads
Spare injector set
Spare turbo
Full gasket Set
Spare CP3
Spare ECM​
Pretty much thays the goal life has a way with monkey wrenches though
1,456
Well got ~15k on engine #4.5 definitely runs better! Able to hold higher mph through hills when heavy to. The oval crackle exhaust note is a lot louder, especially above 13psi boost..
Runs cleaner, mpg is up, I'm sure camshaft would be a lot more effective with more fuel.. part throttle response is substantially better with the Hamilton camshaft vs OEM LMM/LBZ cams.. definitely glad I didn't send it back!
Im sure RLD or similar exhaust manifolds and up pipes would complement the camshaft.
Digmax
289
What about exhaust temp and your oil consumption?
1,456
Oil consumption is back to normal.. used about 6qts additional first 10k. And I've burnt maybe 1qt in last ~5k..been running hills and a trip out to Idaho.. plus I'm running ohio to Carolinas this week..
Fresh rings make egts screwy.. peak temps haven't changed max is about 1150° pre turbo probe is in PS up pipe.
Just rolling on the trottle
With stock cam.. temps would quickly jump 1-200° then level off
With the 192/200 Hamilton camshaft.. I still get similar 1-200° increase.. just takes longer
Tuning is still same as before
8,051
I'll probably wear these rings out... As they are Ductile vs SS that I should have put in it... But didn't know till after the fact.. which will probably be Xmas week
well atleast the ductile certain seats faster than the SS does lol
