I ran the killerbee oil cooler and went from 260+ to a highest if 225 oil Temps towing 12k lbs.
240° oil temp is enough to drop pressure below oem recommend ranges.. with stock oil pump. Which is 18@ idle and 42@1800rpm.
This is 245° oil temp at idle with HV meling316 pump
How much room you got between fuel tank and tcase?
not sure on that. I will take a look. I was thinking about this sandwich plate here: https://www.summitracing.com/parts/ear-503erl. little cheaper than the mushimoto one and it still has a thermostat in it. What about the fact that its only -10 AN? I cant seem to find one that is 12AN.
needs to be -12an. you dont want that being your restriction in the oil supply.
Too bad he is of questionable character to just purchase the oil cooler only and buy the remaining parts elsewhere...:thumb: I asked him awhile back if he would order one for me and I would come by in person and pay cash, he told me no...
There have been tons of people post in various threads saying they use that exact one he posted and work just fine. Find one that is -12 that is readily available I haven't seen one yet.
I run -10 adding the 2 coolers increased pressure drop between pump and #2 main from 8 to 10psi.. considering there is 3 mains bleeding pressure off before #2.. im not worried about it
This is what I'd buy
http://m.mishimoto.com/mishimoto-thermostatic-oil-sandwich-plate.html
What i run for an adapter
https://m.summitracing.com/parts/ham-3321/overview/
Dont forget... i subject my engine to these conditions daily vs few times a month for weekend hauling
i know but you also aren't pushing my power either in the temps i do :angel:
I know where they are readily available from a mfg, same place killer bee gets his. I'll get the info tomorrow.
I just find it ironic that 20* in temp difference is an issue for you but running a smaller adapter plate to the cooler is ok lmao :hug:
You guys can do it, I certainly wouldn't.
