Have you thought about trying a S483 as a single?
Sent from my iPhone.
Were talking about big turbos.:roflmao:
I don't know how Trent's turbos will spool, but the way I have read it, the bigger turbo will receive the exhaust gas first and it will then go to the smaller turbos.
While we're on the subject, saying one turbo spools another is a little misleading because it is the exhaust that spools a turbo, not anything else. Pulling air through the bigger turbo will help it light, but that is not what ultimately lights it.
There is a p-pumped powerstroke that runs a g55 as a single or thats what i was told it was is that big enought.
They make a 106mm GT55, do u think we could turn one of those? It has a smaller exhaust wheel than a Holset HC5A or HX80/HX82... Get the biggest housing possible 4 a GT55...
Do you happen to know the dimensions of the hx82 turbine off hand? they are one bad turbo! The truck I know of takes some time to spool, but when it lights it is down right violent!
Just 4 reference... A GT55 is 4.5 in and 4.1 out, Holsets are slightly over 5" in and a g-trim is 4.4 out and f-trim is 4.1 out.... BIG!!! Like the Garrett thumper units, turbine flows are huge...
according to the turbonetics guy i talked to today, alot of duramax go with the mid frame turbos. they use a large t4 housing and a 82mm/3.230" turbine wheel. and up to the 78mm inducer compressor wheel. billet wheels are available for them as well.
See I thought this was strange too about the mid frames. Looking at my compressor map the flow areas were right in line for what a damx could use (not above 45psi). But when I looked at the more midframe setups everything was right along the surge line. So it makes since that they were surging. I also find it funny that for the cummins and powerjoke guys they list very tiny turbos compared to what he said for the dmax.
I'll probably just go with a turbo that is used more often. I was trying to think out side the box since I already own the tc78. Im sure I can find a use for the tc78 some where else. Maybe put the whole setup with 5.3 in my s-15 I got from my grandpa. Lol.[/QUOTE
That would be your best bet. The seem to move a good volume of air just not at the pressure ratios required for a large single on a diesel. Now if we could run say 5000+ rpm I think they would work better and we would be able to keep the boost down a bit.
Try to talk to the owner of the Rabid Ram and send me a message if you can get any info out of him...
I will give him a call tomorrow. He's pretty forthcoming with information. So it shouldn't be an issue getting the info your looking for. If you want give me your number and I will get back to you later on tomorrow.
