Just put a tuner on my truck
SlowSilverado02
Feb 3, 2015
35
I figured that was the answer I would get. How can you sell something that is capable of giving you 125hp and 325 torque extra and feel no difference?!
N2BRK
1,904
228
they were known for sometimes being a box of rocks. Other times it's the installer's fault -- check your pins for anything bent!. IIRC there were also some special instructions like pulling fuses and such. Re-check the install and maybe you'll get lucky. Otherwise you're SOL and got bitten by a crap box. Go EFI Live :)
Good luck!
Wally
SlowSilverado02
Feb 3, 2015
35
As far as I know everything is hooked up properly. Everything went together very easy. My truck is a very heavy truck (dually) 8' bed and crew cab (4 door).
turbostang7
Apr 11, 2011
239
Rexburg Id.
Doesn't matter if it's a dually, you should still feel a difference. Like stated, check the installation of the edge and make sure nothing was missed or messed up during it.
SlowSilverado02
Feb 3, 2015
35
I'm gonna run the 0-60 and 1/4 tests tomorrow to see if there is a difference. That will help me determine if I'm just loosing my mind or there is a problem.
N2BRK
1,904
228
don't waste your time 0-60 and 1/4mi. Your ass dyno will feel the difference if it's working or not - so it's not. Retrace your steps and see about those additional install instructions like pulling fuses etc... maybe call Edge tomorrow AM if they're open.
SlowSilverado02
Feb 3, 2015
35
Update! I'm an ass, engine wasn't warm there for never gave it any more fuel or timing. It needs to be at 174 degrees for the juice to deliver 100% of the fuel and timing adjustment.
Awenta
4,090
CT
Come back when you get a p0700 :)
I smell it
N2BRK
1,904
228
hahahaha. Now that you know it works, you can sell it for EFI Live :hug:
