Twin turbo build
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I figured I'd seperate the compounds build from my engine thread. Started ordering parts last week and they started showing up today.
So far I have in possesion:
Turbo
Turbo blanket
S400 vband for hot pipe
Turbonetics outlet vband
Triple pillar pod
Boots, hoses and clamps
Oil feed and return line
And a few pieces of the pipe I ordered.
Everything else should be here by Wednesday or Thursday this week.
Still waiting on:
100 psi boost gauge
Remaining pipe
Coolant tank (picking it up in the morning)
I'll be putting a custom turbonetics y2k 88mm over my billet s472.
Specs on the turbonetics:
88mm hpc billet wheel
101/112mm turbine
1.23 ar turbine housing
Ball bearing
Hot pipe between turbos will be 304 stainless, charge pipe is mild steel and downpipe will be made from aluminized steel that I had laying here.
Can't wait to get this started. As far as I'm concerned, I can get the turbo mounted, oil lines hooked up and down pipe built until the rest of the parts show up.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Some time between last september and now I apparently told the wife we could go to hawaii this year for our 1 year anniversary. I guess I gotta keep mama happy too...injectors will have to wait...that is of course unless the right deal comes along;)
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Yes I'll have an air filter the turbo came with that slip on bell mouth. It slips on and off. I won't ever use the bell mouth.
5,912
375
Mike have you looked into extrude hone? I called the other day and they can take stock nozzles and hone em.. I asked about 60%s and it was $55 a nozzle..
