Why Injector Flow Testing Is So Important
Trippin
SoCal Diesel
Aug 10, 2006
663
Here is a pic of an LB7 nozzle that was Extrude honed by company XYZ and installed into a truck. The customer wasn't happy with the way the truck ran and finally sent the injectors to me for evaluation.
As you can see under extreme magnification in the pic, a piece of debris must have clogged one of the holes during Extrude and because no one was checking the spray pattern or overall flow at 28,000 psi, it was overlooked.
  • Bad extrude hone job.doc
13,597
627
Guy, what do you charge to hone and test a set of injectors?
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
Guy, what is the approximate turn around time and cost for you to hone a set of injectors, Please PM me some details :)
Trippin
SoCal Diesel
Aug 10, 2006
663
When the customer supplys injectors it usually runs around $1500 to enlarge, test and calibrate. This assumes the injectors don't have any inherent problems. Always good to start with a known good set.
If we have to chase down and solve issues, it runs an additional $120/hour.
Average 2 week turn around.
13,597
627
What about just to test a set of already enlarged injectors and match them if they are off slightly? Same price?
Trippin
SoCal Diesel
Aug 10, 2006
663
I modify, test and calibrate your injectors, or I can supply you a new set, modified, tested and calibrated.
Guy
