My dad wants to look at an 2002 lb7 dump truck this weekend. Truck currently does not run.
The ad says "injectors changed now will not start"
truck has 103k miles on it
When talking on the phone the guy said- took it to a shop, said #2 injector was bad changed it, now truck wont start.
Seller says it ran fine up till then.
The truck is listed cheap enough it could be worth taking a chance on. would like to make sure that the motor is at least good, and it only needs injectors hopefully.
I figure I can at least check for codes with my scanner and put a socket on the balancer to make sure it doesn't have a broken crank. just looking for ideas on what else I could check motor/trans wise without it running
