What threads are the cooler fittings?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
For which trans. I know the cooler ports in the bellhousing are a -8 AN for the 01-early 03 trucks, and -10 an for 03+. Cooler fittings at the radiator and aux cooler varied.
Mogman
341
17
Papalote, TX
Sorry, brain fart it is an 08 6 speed Allison 1000, I need to know what the threads in the aluminum case are so I can remove the fittings that use the clips and replace them with 5/8 JIC or 10-AN for you aircraft nuts.
Mike L.
15,686
232
Fullerton CA
7/8 by 16
Reactions: Mogman
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Yes, it's a -10 with an o-ring where the fitting goes into the case iirc. Just make sure and use a hose that can handle the heat. I used some 275 degree rated hose on mine and they kept leaking from the heat breaking the hose down everytime I towed something. Ended up going with some 325 degree rated hose.
