Oh wow. I did that to my middle finger on my right hand a LONG TIME ago. Luckily they got it back together and everything is fine. Nail is jacked up and no feeling in the tip though. Lol
Does your truck have the original motor?
Compared fuel economy. Kinda shocked how close they were. Pulling Identical trailers.
750 miles.
2010 GMC LMM with 817k filled 70.89 gallons
2013 Chevy LML with 430k filled 70.95 gallons
Been plumbing brakes lines on the 35' Crossman... Those nicop lines are nice!!
Running 1/4" line from the pump in the neck, down to the axles. Have 7/16-24 to -3AN adapter.. and Dot -3AN SS line(18") to the caliper..
Theoretically.. the -3 flex line should act as an orfice, making all for brakes it at once.. with the To at roughly the center of each axle.
While the front axle should hit first.. rear should be shortly after it
Calipers are 3 3/8" diameter times 4.
Went with 1/4" vs 3/16 due to there's 28' of line between pump and forward axle..
And fluid dynamics size times length equals restriction.
Get pictures in the daylight..
Got to wire the pump and 9amp hour battery vs the 5am for e brakes..then bleed it Should be ready to go
