how can you tell there not fireing and wht would cause thtTommy your injectors arent firing. Does it show a constant 9,000psi when cranking? Or just for a split second? You should also be showing ~180psi rail pressure with the engine off. Make sure the batteries are charged, that cranking rpm seems a little bit low too.
because if you look at "max" pulse width its zero.
Hmmm irc jasons showed zero untill his truck started as well. but could be wrong
I would start by going back to a single cp3 just for first start up and take one thing out of the way.Other then that timing, did you put the pre load back on the cam gear before installing?
Interestin thanks Henry.
IIRC Tommy was one of the first LMM's to get dual CP3's. Many moons ago!!
I figured that it would just show pw from the tune rather than actiual from the injectors.
I'm not sure if Tommy had the dual cp3s hooked up when the old motor was in since he asked for the install info a few days ago. That would just take one factor out of the way once its running then hook it back up it it doesnt start again after that he will know it was something miss wires or just guffy acting, The smallest things can screw with you on these truck.
On the cam the older motors had a single one piece gear on the cam,on the newer motor we have a 2 piece gear that has a tension spring thta has to be preloaded, If this was not done timing could be off some.
It's also said that if the injectors are not installed into the same holes that they came out of the truck will not start also, If the injectors are replaced with ones that are oversized I know it will start no matter what hole you reinstall it in, I hear its only with the stock injectors with the programing from GM.
I thought the hard part was going to be bulding and instaling not turning the key lol
Yea i did have the dual ppe in there before but ppe did the install. I was really suprised tht tht nipple on the rail is left open like tht. I know there is a possability tht 2 injectors are not in there stock locations. If this is the case wht could be done to rectify the situtaion ? could i recopy the gpcm info again ? or does this require a tech 2 if they got swiched? could this really keeep the truck from starting ? thanks for alll the help and ideas every one :hug: I thought the hard part was going to be bulding and instaling not turning the key lol
yes I preloaded the gear when it was installed![]()
I taped power for my dual cp3's from the little red power box and then also grounded it from that spot were you hook to jump start.
Preload? WTF i dont remeber doing this?![]()
