shims thick side is pointing forward. I'll see if I have a picture of it.
Sent from my DROIDX using Tapatalk 2
how thick is the otherside of the shim?
Do not know this and can't find a picture for this. Will be back by the truck friday and get this information for you.
its hard to see the shim unless your talking about the silver block. if your talking about the little plate under it, thats not enough shim to get you at the right angle. what i find odd is the thick side pointed toward the front of the truck. Normally when you lift a truck with springs or a flat block, the pinion is pointed too much toward the ground and your trying to raise it back up. this is why most lift blocks are tapered and the larger side of the taper goes toward the back of the truck.
If you take the shim out based on everything you have given us, your vibration and pinion angle will become worse. you need a thicker shim in there to point that pinion flange down more.
can you get us a few pics of the leaf springs, shackle, and back side of the block as well? i just want to be 100% sure your text is matching what is on the truck. Absolutly no offense to you as im sure you know what your talking about but what makes sense to you dont always make sense to me cause im stuck in 110* heat all day . pics speak 1000 words :hug:
See, I don't think the pinion should be rotated down. The carrier was pointed slightly down toward the axle, shouldn't the pinion slightly point toward the carrier then? I'm quite sure the angles need to be close. If the carrier is pointing 10 degrees down, the pinion should point 10 degrees up. The exception is if a double cardon joint is used, then you want the pinion pointing at the cardan.
So where I'm getting mixed up is the carrier, and it is all the angles that need to be accounted for. I guess the slip spline after the carrier lead me to think the angle after the carrier played a larger part. Thanks.
Ok I lied...rearward is thick side and 3/8"thick
