Upgrade pump or nozzles
Yngdmax92
962
Here we go guys.
Big tune on my truck is dropping rail off to 25000 when commanding for 27-28k.
Lbz with 3794 stg2, the fuel system is stock. Should I upgrade the pump or do some injectors first and if so what size?
13,862
966
I would do injectors before I did a CP3 unless your CP3 is bad. Size depends on horsepower goal.
ZeroGravity58
1,420
54
Maryland
When I had my big tune on my lb7 it would drain the rail with stock injectors. I upgraded to 50 overs with the same cp3 and the truck picked up 4 tenths in the quarter. So unless the cp3 was bad I'd do injectors first.
Yngdmax92
962
3150us
I was leaning that way too. I'd like to keep this lbz alive as long as possible, we will see. So go with 45 or 60 overs??
Dozerboy
5,088
683
TX of course
Injector would be your wise choice. Do you want more power or just take some stress off the engine? Is 3150us your daily tune? Bigger cp3 could do both if your not holding rail on your daily tune. That way you could run less PW and make same/more power because you have more pressure.
Size injectors depends on you end HP goal. 60 overs are going to limit you if you twin your truck down the road, but I don’t know you can do 100overs with a stock cp3.
Yngdmax92
962
3150 is my race tune. I'm looking to take less stress off the engine. I figure staying with a stock cp3 will keep my engine alive the longest as well.
I thought if I got larger nozzles, I could cut the duration a bit and on the back side of things bring back up the psi in the rail.
Yngdmax92
962
What size can you go up to, before you have to send them out and get them balanced and flow rated?
Could you just buy some 60 overs and swap them out for stock ?
Brent@LDS
651
Wisconsin
It's a good idea to have any oversized injector tested/balanced. We test, calibrate, and balance all our injectors here within less than 4%. Let me know if I can help you out or get you pricing.
Yngdmax92
962
Pm me a price for 45% overs and 60% overs plz
Yngdmax92
962
Just thinking fellas,
You think I should try a rail plug before I go ahead and buy a pump, it'll hold 2800us, once you command for more it dies off to 24-25k psi. It's completely stock fuel system lbz with airdog 165.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Yeah it’s worth $40 and I think everyone needs one to prevent issues later on. I’ve replaced a lot of failed plugs
8,064
Do the bottle test. Pull the little hoop rubber hose in front of the fprv, put a longer hose on the rail side and plug the return side. Put the long hose in a gal jug and tuck under the hood somewhere. Go drive it hard on the big tune and see if there is any fuel in that jug afterward. If there is, put a plug in or shim the fprv. If there isn’t any, that’s not your issue
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
Just throw a plug in and make sure it isn’t leaking. I would hate to lose a race because the FPRV decides to pop open. You also want to keep your pulse width close to stock.
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
Ah depends on your goals and location. I ran and still do run stock injectors with a modded pump. 3300pw, 75mm turbo and Modified LLY pump. 700hp and 11.8 1/4 mile ET. Plenty of ways to get it done.
Yngdmax92
962
Good thinking, I'll report back when I get it done.
