Really have to say, really cool to see all the different loads on your trailer and what not.
I have to ask, do you like your Kaufman trailer? I bought one new in 2012 (25+5 tandem dual) and have some mixed emotions on it. I was just curious seeing you mentioning that your looking into getting a different trailer.
Keep up the good work!! :thumb:
:thumb:
thanks, its not bad but that's not to say it isn't great either.. mines 2012 26+4 tandem 8ks.
had several issues at the beginning. for ~$7,000.00 I wouldn't have a problem towing my sled, drag truck around during the season, or around the farm work. running hotshot, in a continuous duty fashion (2000+ miles a week) it wouldn't be my first trailer again.
Kaufman proprietary spec'd out a 8k axle from lippert. a heavy wall (5/16") 3" tube std 8k bearings and a std 7k brake(12x2), instead of using std 8k brake of 12.25x3.375. to make matters worse you can only get said hub/drum from either lippert or kaufman.. I eventually bent both axles that came with the trailer.. I went to appalachain trailers which sell std 8k axles dust cap to dust cap with springs for 600.00 each with std 8k brakes, which I have, while not on propose, overloaded them up to 25,000lbs on the trailer axles and they are not bent.. and lasted twice as far.
mind you dexter wants ~1200 for each axle spec'd the same... only down side grease hubs every ~10,000 miles which is about every 5 weeks..
another problem which could have been related to a new sales rep... I asked for a lowered couplet with gussest, my pin/ball height is 31-32" vs 36" most of the newer trucks are. which resulted in having to have the tube fully extended making the trailer to buck f/r like a std farm wagon. which lead to ripping the welds at the bottom of the neck.
the fixed it under warrentee cut the old one off welded a new one on and dropped it 6" with gussets. I then add 2 3/4" bolts to clamp it since the jam bolts never stayed tight. since I put the bolts in the coupler I have had 0 f/r bucking
another issue I had that was resolved under warrentee was some frame cracking.. the sub frame is built separately then welded on to the main beam. which is all good an fine... problem is they weld the subframe in suspension/hanging under the trailer, and weld it on the outer lips with couple dozen 5" welds.. so the trailer ride on the welds vs face of the I beam. I could fit a .040" cut off wheel in the gap.
this was their "fix" .375"x5" plate. 2 26' long sticks welded in suspension/hanging with diamond fish plate inside and out at each rip area plus grind and welded up the rips. there was places I could see the other frame between the I beam and 3/8" plate....
not too mention it was ~11lbs a foot * 56' that was welded on... wasn't happy about losing ~600lbs in cargo capacity.. though I got some ~4000.00 worth or parts and labor at the cost of 2 days sitting for free...
plate was a cheap lazy fix IMO. I eventually cut everything off.. minus the stuff between the subframe and I beam +2" front and rear of the sub frame and 6" of it that was welded to the neck area.
I bought 2x2x.25 square tubing ~5.1lb per foot, I used the 2" lip as a base cut 2 18' sticks, placed two 2x.375 plate along the I beam and laid the tubing ontop and welded it in compression vs hanging as depicted in the picture.
as to how the bridge works.. I have place 8,000lbs dead center between pin and tandems with no discernable flex/bow in the deck. before in original OEM setup 6,000lbs in same spot would bow the trailer~.5" down.
another thing I noticed before the bridge the deck would bounce up and down while going down the road, you would feel a bump as each axle group then reverberations as the shock way went through the deck.
with bridge I would say 90% of the reverb is eliminated along with added torsional stiffness.
like I said its not a "bad" trailer but its not "great" either. welding the neck upwards vs downward and components in compression vs suspension would have eliminated a lot of issues they had to fix.
a bridge "should" be available as an options AFAIK none of their trailers have that option they didn't at the time I ordered mine.
my next trailer I plan/dream on getting is a 25+5 Crossman aluminum trailer.. and they are about ~10k more than a similar spec steel trailer but some 3,000-4,000lbs lighter.
gatormade and PJs are stupidly overbuilt and heavy, big tex and load max are built on par.. one of those 4 would get the nod if I went with steel trailer..
which that trailer is going to be a
25+5 fold flat ramps, popup dove, 12k axles single aluminum 235/70/17.5 tires, EOH disc brakes, air ride with lift axle. with air being self contained and be able to take supply air from tow vehicle. and said trailer WILL have adjustable suspension for alignment reasons.
for an almost 3yo trailer that is pushing 200,000 miles on it.. outside spring eye bushings, equalizers, brake magnets all which are wear items. I have put 2 new axles under it, and ~$250.00 worth of steel and replaced 2 deck boards, couple lights that corroded due to no die electric grease, its has been rather touble free..
as for the neck and frame ripped with less than 40,000 miles on it I bought it in march '12 they did the repair work in june/july time frame of that year.
paint quality sucks, though they don't put a good quality paint on it to begin with...
with that novel stated... what have you had problems with?
