Tricky boost leak
Moneywellspent
Dec 27, 2013
236
Idaho
So I'm about to hunt down a boost leak in my system. The only thing is I think it's coming from o ring in my v-band clamp. And that's located on the discharge of the turbo. Any good tips how I would go about checking that one spot? Or should I just take it apart and throw a new o ring in?
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
Spray soapy water around welds and boots/clamps. It will be easy to spot without much pressure then.
If you don't want to build a boost tester, have someone brake stall the truck while you watch.
Harbin_22
3,858
Southern Indiana
If the oring isn't damaged, than yes this will work. Have to do it on my twins every once in a while. Just gets the fittings wedged in a little tighter.
