trans go jr
timruger1
Apr 10, 2012
I had my trans go jr installed about 3 months and 5000 miles ago
It has pretty much smoothed out with the exception of reverse
It now intermittently clunks when i put it in reverse
any ideas?
15,686
Transgo valves should not have any bearing on your garage shift to reverse as they work like stock valves until a certain pressure is reached. You may have a draggy trim valve or something else is causing your rough shift. Have someone with a Tech 2 clear your garage shifts.
timruger1
Apr 10, 2012
trans clunk
Truck has 44k on it and it didnt start until the transgo.
No its not the U joints
I assume a tech 2 is a type of scanner. I will check and see if I can get those garage codes cleared
thanks
03spoolindmax
Nov 9, 2011
674
Mi
thanks
There's no codes. What mike means is after a rebuild or any modifications are done to the trans you have to reset its memory. The Allison is constantly adapting and learning your driving habits. When you clear the garage shifts. It resets them to relearn how to shift from reverse or drive and learns how to engage smoother.
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Efi or a tech 2 are the most and best ways to relearn the tranny... However correct me if I'm wrong worse case if he has a cts or something similar can also relearn the tranny, just not as in depth process...
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
How does trans go work.
The TRANSGO valves have the check valves in the end of them that allow them to go to full line pressure where the stock valves are limited to roughly 125PSI max. The check valves open at roughly 60 PSI commanded, so this allows the TRANSGO valves to work as the clutch packs are engaged by about 45 PSI. This allows the TCM to have control of the engage and release, but once the packs are engaged the TRANSGO valves allow full line pressure to them.
I'm sure others can give a better description of how they work as I have a tough time putting how things work into words.
timruger1
Apr 10, 2012
trans clunk
My neighbor has a snap on analyzer I will see if he can clear the garage settings
Worse case, if I leave it will it eventually relearn on its own and stop?
