Tow haul button not working
LOWTAHOE2
Aug 16, 2021
3
I know this topic has been beat to death but I have this problem as well. It has a brand new shifter and it still doesn't work. Does anyone have a diagram for it? Can any one tell me possibly where the wiring goes or a power source .
1,732
this is all I was able to find right now. looks like you should ohm out the line down to the BCM
1,732
the BCM is under the steering column. lay on the floor down by the peddles and look up by the column and you can see the TBC (BCM). the other side is of course the tow haul button. pull the connection J3 off and test the B11 terminal to ground when pushing the button
